Mirror Adhesive Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-12-2007, 10:15 AM   #1
i have a 15.5" x 30" high mirror that i want to place in my 1/2 bath.
can i use adhesive mastic? do i have to make sure my wall is primed?
can i place the adhesive onto the painted drywall?
thanks for all your help!
Designman20 is offline   Reply With Quote
Old 11-12-2007, 11:32 AM   #2
so-elitecrete
Rewards Points: 150
i need to know, too, 'cuz already glu'd mine (72" x 42" ) onto painted drywall,,, used plate glass clips on the btm & 1 on top ctr while the adhesive was curing,,, so don't worry - its been up 3yrs w.no problems.
so-elitecrete is offline   Reply With Quote
Old 11-13-2007, 07:27 AM   #3
I am curious also... I want to add a mirror backsplash (15x24) above my pedestal sink, below my mirror medicine cabinet... I am short, DH is tall, so we had to mount the cabinet a bit higher than normal. Can it just be glued to the sheet rock?
leezarrd is offline   Reply With Quote
Old 11-15-2007, 08:25 PM   #4
remodeling pro
Either primed or painted drywall will be ok. Unless the botom of the mirror is resting directly on the spalsh, you will need some type of clips to help carry the weight.Use only mastic designated for mirrors, most "general purpose" mastics will damage the mirror.
troubleseeker is offline   Reply With Quote
Old 11-18-2007, 09:38 AM   #5
Excellent advice. Those clips troubleseeker refers to are small and unobtrusive but an essential safety consideration. Liquid Nails makes a mirror mastic in a caulk gun cartridge that has a very fast grab and a tight hold.
End Grain is offline   Reply With Quote
Old 11-18-2007, 10:17 AM   #6
Thanks for the info! You're great!
Old 04-18-2011, 10:29 PM   #7
i am making a mosiac glass mural on the side of my vintage camper which is aluminum what is the best adhesive to use???
lindaccookie is offline   Reply With Quote
Old 04-19-2011, 02:12 PM   #8
Rewards Points: 83
Question:
I have in the past attempted to glue a mirror to a visor in my car and found that after a few weeks the back reflective part of the mirror pealed off of the glass so now all i have is this reflective material glued on to my visor but the glass fell off long ago.
Would this not also be the case if you only glued a mirror to a wall and didn't use the little clips?
linuxrunner is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
