Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-24-2010, 07:49 PM   #1
Mildew
What is the fastest and easiest way to remove mildew from concrete block walls? I have this problem in my basement and I need it gone as fast as possible. Thanks!!!
rdesmond is offline   Reply With Quote
Old 01-24-2010, 08:56 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
Mildew
50/50 mix of bleach and water.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 01-25-2010, 07:14 AM   #3
gravity always wins
Mildew
10% bleach / 90% water. Spray it on. Use a scrub brush, then rinse and dry. Never exceed 10% bleach. You create a lot of nasty chlorine compound gases that you don't want to breathing. 10% Bleach is all that's necessary anyway to be totally effective.
Old 01-25-2010, 09:51 AM   #4
Household Handyman
Mildew
I'm with "Maintenance 6" on this mixture. Please wear some type of safety glasses and gloves. Not only does a 10% mixture burn the eyes, but can cause damage. Even at a 10% mix chlorine/water will/can be absorbed through the skin and get into the blood system, if exposed enough. David
Old 01-25-2010, 09:56 AM   #5
brokenknee's Avatar
Mildew
Sorry, I goofed on this one. I do recall now that 10% bleach is all that is needed.
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
How to remove mildew from wet wood bofusmosby Carpentry 11 07-16-2008 02:16 AM
