-   -   Microwave trips GFCI on a different circuit! (http://www.diychatroom.com/f2/microwave-trips-gfci-different-circuit-21467/)
Frank Kolwicz 05-26-2008 11:38 AM
I've read about a microwave tripping it's in-circuit GFCI, but mine trips a separate circuit at the opposite end of the house and only when my computer is running on that second circuit. This started only a few days ago after almost 5 years of normal operation.
I've replaced the GFCI and it persists.
I moved the microwave into another room on a different circuit and initial testing indicates that everything may be back to normal, but that isn't a convenient place for the appliance. Also, the microwave recently started making a new noise, a buzzing, on start, whether this is coincidental, I don't know.
Your advice is appreciated,
Frank
nap 05-26-2008 12:32 PM
is there anything in common with the two circuits involved, such as the neutral (as in a multiwire branch circuit)?
Frank Kolwicz 05-26-2008 02:40 PM
RE: Microwave trips GFCI on a different circuit!
I don't know and don't know how to find out.
They are on separate circuit breakers and in far ends of the house, so I would *presume* that the only place the ground wires came together would be in the circuit breaker panel box, just like all the individual circuits.
Frank
nap 05-26-2008 06:19 PM
the ground wires are different that the neutral wires, Figuring out if they are on a common neutral is not difficult but if done improperly, can damage anything plugged into either of the circuits..
the easiest and safest way I know to check is with a clamp on ammeter. Got one laying around by chance?
Frank Kolwicz 05-26-2008 06:43 PM
I've got a 10A multimeter, what kind of clamp? Spring clamp, "C" clamp? What is the procedure?
Frank
gregzoll 06-01-2008 04:45 PM
Either bad GCFI outlets, or too much load on the Circuit. As for the Clamp-on, if you want to use a C clamp, go ahead, but what the OP is talking about, is a device that uses Induction to take the reading.
Frank Kolwicz 06-01-2008 07:56 PM
It's moot now, I've replaced the microwave and everything is back to normal.
Frank
Super33 06-01-2008 08:48 PM
damn frank you beat me to it. Was about to ask why nobody's telling you to get a new microwave because it's obvious that's the problem.
