-   -   Microwave hood installation (http://www.diychatroom.com/f2/microwave-hood-installation-81047/)
wilderstyle 09-10-2010 09:13 AM
Got a new range and microwave hood. Can we install the hood to the wall before we purchase the cabinets and install those later?
epson 09-10-2010 09:23 AM
I would wait for the cabinets first, and then install the hood.
troubleseeker 09-10-2010 12:22 PM
Definately not a good idea, as the location would have to be laid out with extremely close tolerances. The only scenarios where I would recommend doing this in a typical DIY project is if both ends of the run of wall cabinets were open ended (do not butt against a wall), in which case you could later hang the microwave cabinet first (matching it to the microwave location exactly) and then work out in both directions; or if one end had a blind corner(which would give you some leeway for adjustment later. It is not an impossible task, but I would not recommend it if you do not have much expeience with laying out and hanging cabinets. Also, the micro/hood unit is designed to be suppported by the cabinet above it. The flimsy wall mounting plate cannot support the unit cantilivered out from the wall.
Ron6519 09-10-2010 05:10 PM
It would help if you stated the entire job concept. From the post it seems like you are redoing the kitchen, but in a backwards sort of scenario.
Ron
