Metric Screws? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-23-2016, 02:11 PM   #1
Rewards Points: 314
metric screws?
Chinese made electrical heater has torx screws.
I wish to replace them with normal screws as it has to be taken apart for cleaning.
they are the type that screws into plastic. not nut and bolt type.
they are between a 6 and an 8 non metric.
someone measured them as 4 mil. the thread part is about 1 and a 1/2 CMs.
what do I order!
what are they called.
I am in Canada but everything in the local stores aint metric!
thanks all
anon125 is offline   Reply With Quote
Old 01-23-2016, 03:24 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
just buy a torx bit, lots of things are put together that way, a set is cheap.. http://www.amazon.com/Bosch-CC90396-...ords=torx+bits
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
Bondo (01-23-2016)
Old 01-23-2016, 07:01 PM   #3
Rewards Points: 2,646
Torx is an excellent drive type. Why do you want to replace them?
SPS-1 is online now   Reply With Quote
Old 01-23-2016, 07:18 PM   #4
ZZZZZ's Avatar
Rewards Points: 652
In my town anyway, Home Depot & Ace Hardware sell metric screws.
ZZZZZ is online now   Reply With Quote
Old 01-23-2016, 07:26 PM   #5
Rewards Points: 314
They are pretty terrible torx screws! A real pane to remove.
All stores round here have nothing like it.
So I would have to order the replacements online in Canada
Old 01-23-2016, 08:01 PM   #6
A screw that does not come out easily is normally considered a good thing. At least the Torx drive allows you to readily put a lot of torque on the screw without the screwdriver camming out.
If I understand you correctly, those are self tapping screws made for plastic. You are very unlikely to find something like that at a hardware store. Could actually be a proprietary thread form. But make sure the thread matches exactly or you will strip out the plastic piece.
Old 01-24-2016, 12:49 PM   #7
Rewards Points: 314
apparently they are tamperproof. so the correct screw driver barely fits.
thanks all
Old 01-24-2016, 01:08 PM   #8
you need this then...http://www.harborfreight.com/100-pc-...ase-68457.html
Old 01-24-2016, 02:11 PM   #9
dd57chevy's Avatar
Rewards Points: 1,092
Not sure what hdwe stores you have in Canada , but my Ace hdwe has a sample board with nuts & screws so a guy can indentify what thread he has .
The next place would be Fastenal or something similar .
dd57chevy is online now   Reply With Quote
The Following User Says Thank You to dd57chevy For This Useful Post:
SeniorSitizen (01-25-2016)
Old 01-25-2016, 03:30 PM   #10
Rewards Points: 314
Originally Posted by ShtRnsdownhill View Post
I have the correct screwdriver.
Old 01-25-2016, 03:35 PM   #11
Rewards Points: 314
Called the local fastenal. No metric. Thanks
Old 01-25-2016, 04:20 PM   #12
Rewards Points: 2,906
Probably the largest fastener wholesaler in Canada is a company called Spaenaur.
Give their Customer Service people a call at 1-800-265-8772 and describe what you need. They should be able to give you a page range on their online catalogue where you can identify the kind of screw you're looking for. You'd then have to order that same screw with a different drive or different head from any place that deals with Spaenaur. Almost every place listed under "Nuts & Bolts" or "Fasteners" in your yellow pages phone directory will deal with Spaenaur, but some of them might have minimum orders.
If Spaenaur doesn't have it, it's not made.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-27-2016, 01:18 PM   #13
Rewards Points: 314
will give them a call.
thanks
Old 02-01-2016, 02:08 PM   #14
Rewards Points: 314
Spaenaur. says the have no metric self tapping screws.
thanks
Old 02-01-2016, 02:11 PM   #15
post a picture of the screw next to a ruler for sizing..
Composite vs wood deck screws cranedk Building & Construction 6 11-26-2015 03:47 PM
Loose stainless steel deck screws drtbk4ever Building & Construction 17 06-19-2012 09:26 AM
Construction screws - interior framing miamicuse Building & Construction 15 05-05-2012 05:56 PM
Certainteed Metric Landmark TL, English Shadow Ridge?? oldgrunt Roofing/Siding 1 12-08-2008 11:20 AM
Metric. Yes or no? Explain your answer. elkangorito Electrical 42 04-08-2008 02:51 PM
