Metal Post Bent - Issue - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-26-2014, 05:27 PM   #1
Solutions (handyman)
Rewards Points: 362
Metal post bent - issue
A gate post (about 6" x 6" x 8') was hit by a loader during snow removal. The post is slightly bent. Is there a way to straighten the post by heating it or cutting and re-welding? Any advice is appreciated
Mark Harvey is offline   Reply With Quote
Old 01-26-2014, 06:10 PM   #2
DIY staff
Rewards Points: 7,174
Yep---you may need to heat the inside of the bend until red hot---oxyacetylene would do that---
Any skilled heavy equipment welder will have experience with that job---
Mark Harvey (01-26-2014)
Old 01-26-2014, 08:49 PM   #3
joed's Avatar
Rewards Points: 11,588
How 'slightly" bent is it. A come-a-long might pull it back straight.
Old 01-30-2014, 03:21 PM   #4
Rewards Points: 808
I'd say it's a futile effort at best. It's steel, and square. It's not just bent, it's kinked. The ground was probably frozen. I'd replace it.
IslandGuy is offline   Reply With Quote
Old 01-30-2014, 04:12 PM   #5
Can you post a photo of the post?
Hardway is offline   Reply With Quote
Old 01-30-2014, 04:36 PM   #6
Rewards Points: 392
It would be a lot easier to replace given the fact that it's 6x6" as that will not be easy to straighten.
rustyjames is offline   Reply With Quote
Old 02-12-2014, 10:43 AM   #7
You can cut above the kink and below it. Grind edges to a 45 angle and tack weld it straight. Fill the weld with appropriate stick and then grind the sides flat. The grinding is the hardest since you will need a bunch of different grits and then prime and repaint. Most likely it would be easier and cheaper to replace unless you have the tools to do the previously stated. Good luck
maintguru@hotma is offline   Reply With Quote
Round metal lamp post DJM1955 General DIY Discussions 11 08-27-2012 03:32 PM
Beam build, joint not over post WillK Building & Construction 8 01-03-2012 10:31 AM
Metal Halide lighting issue. Jere Electrical 3 04-20-2011 01:24 PM
Post problems WillK Building & Construction 8 03-28-2011 07:16 PM
post and pier repair question tcameron Building & Construction 6 11-14-2007 08:07 PM
