Metal Front Door With Screws That Keep Coming Loose - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-27-2008, 03:45 PM   #1
Metal Front Door with screws that keep coming loose
I have a handle on a metal front door and the screws keep coming loose. Seems like the hole has gotten bigger than the screws. Can't really put bigger screws in it because a bigger screw won't fit thru the handle. Any suggestions other than buying a new handle?
MicheleWilliams is offline   Reply With Quote
Old 12-27-2008, 03:53 PM   #2
fhi vinyl windows
fhivinylwindows's Avatar
Rewards Points: 150
Is this a metal storm door or a steel entry door?
Assuming (might be wrong) that the screws are actually bolts, try some lock-tite.
fhivinylwindows is offline   Reply With Quote
Old 12-27-2008, 03:57 PM   #3
It is a steel entry door. Would Lock Tite work if the holes are bigger than the screws
Old 12-27-2008, 04:05 PM   #4
fhi vinyl windows
Rewards Points: 150
I don't understand where you think the screws are going into the wood unless you are talking about the latch on the side of the door. The inside and the outside of the handle are connected by bolts. If you are talking about the latch then I would suggest a golf tee and wood glue----> fill hole with glue--->drive in a golf tee----->complain about the glue all over the place/clean it up----->wait for the glue to dry----->redrill hole locations with 1/8" bit.
Old 12-27-2008, 06:45 PM   #5
A golf tee will work in a metal door?
Old 12-27-2008, 09:32 PM   #6
fhi vinyl windows
Rewards Points: 150
I give up, post a picture.
Old 12-27-2008, 10:49 PM   #7
Rewards Points: 5,336
Only if Tiger Woods installs it. No, really!
Ron
Old 12-27-2008, 10:59 PM   #8
Custom Cabinet Maker
drive a plastic wall anchor into the hole in the door, then you should be able to screw the handle tight
skymaster is offline   Reply With Quote
Hollow metal door and screws. dturnip1 Building & Construction 5 11-16-2008 01:58 PM
Carpet coming loose on the stairs-how to fix? imola ghost Flooring 1 09-22-2008 08:22 PM
screws coming loose Baffeled Building & Construction 4 08-13-2008 09:48 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
help, loose door hinges screws clyde Carpentry 13 12-19-2007 02:31 PM
