Metal Break Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 08:08 PM   #1
Rewards Points: 190
metal break question
Just a quick question.....if i bought a 30 inch metal brake and i need a 54 inch piece can i bend the metal and slide it on the brake to make 54 inches? I never used one before and want to check before purchasing one....
ryanb4614 is offline   Reply With Quote
Old 04-14-2013, 08:13 PM   #2
Rewards Points: 13,270
What is it your really trying to do?
No idea on what type brake your trying to use, there's several differant styles.
It would be far cheaper to rent a brake at Home Depot or even hire a siding company to do the bends for you then to buy one for a one time use.
Old 04-14-2013, 08:14 PM   #3
Originally Posted by ryanb4614
Just a quick question.....if i bought a 30 inch metal break and i need a 54 inch piece can i bend the metal and slide it on the break to make 54 inches? I never used one before and want to check before purchasing one....
We have a 10' break and I've made plenty of 12' pieces. Sometimes there is a little kink or buckle where the break quits; if you bend 15-30deg at a time though you can reduce and/or avoid the kink.... Depends what you're bending too I suppose....
Justgaff is offline   Reply With Quote
The Following User Says Thank You to Justgaff For This Useful Post:
mae-ling (04-14-2013)
Old 04-14-2013, 08:15 PM   #4
Rewards Points: 190
Window casing and roof flashing
Clearcoating a Stripped Vintage Ferrous Metal Medicine Cabinet? Lovegasoline Painting 15 08-31-2013 10:32 PM
Question on Grounding 3-Gang Metal Box GeorgesAA Electrical 3 04-14-2012 01:43 PM
metal outside corner question? Yeti Drywall & Plaster 3 03-16-2012 05:54 PM
Plumbing vent Question - ABS to Metal CAD Plumbing 2 11-15-2009 04:32 AM
How to drill through metal in headers Docfxit General DIY Discussions 5 07-05-2009 11:31 PM
