Medicine Cabinet Shelves - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-07-2013, 09:37 PM   #1
Rewards Points: 1,584
Medicine cabinet shelves
I have a medicine cabinet that has three sections, each about 11" wide, total about 34", and each section has it's own mirrored door.
The cabinet shelves are made of MDF, and it's 33" long by 3.5" wide, 3/8" thick. Over the years due to moisture, spillage of liquid medicine these shelves have bowed and swollen in spots.
The shelves rest on shelf insert "pins" on
I am thinking of replacing them with a different material.
1/4" thick tempered glass come to mind.
Any other materials to consider? I don't want to go back to MDF shelves.
miamicuse is offline   Reply With Quote
Old 10-07-2013, 09:42 PM   #2
Rewards Points: 3,130
A medicine cabinet with MDF shelves can't have been expensive to start with. Maybe you should consider replacing it - I think the best shelves would be tempered glass, but they would probably cost more than a new cabinet.
The Following 2 Users Say Thank You to md2lgyk For This Useful Post:
joecaption (10-08-2013), Two Knots (10-08-2013)
Old 10-07-2013, 09:57 PM   #3
I considered it, but decided not to.
The entire bathroom is tiled, the cabinet was obviously installed prior to the tiling as the wall tiles and backsplash tiles were installed "around" it. Unless I can find something with same exact footprint I don't want to open a bigger can of worms.
Old 10-07-2013, 10:17 PM   #4
Davejss's Avatar
Rewards Points: 740
You could use Azek or another brand of plastic board. Personaly, I'd go with the glass.
Davejss is offline   Reply With Quote
Old 10-08-2013, 09:08 AM   #5
Another possibility: Plastic kitchen cutting boards are inexpensive and can be bought just about anywhere. They cut easily on a table saw. Make your own shelves.
Old 10-08-2013, 10:11 AM   #6
Note the dimensions. 33"+ length by 3.5" width.
The shelves are only supported on the ends by shelf pin inserts.
The material must be stiff or it will sag in the middle.
Old 10-08-2013, 02:32 PM   #7
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
I built a 60" bookcase out of 1"x6" for DVDs five years ago. I knew it was going to sag, so I just cut several extra pieces of wood to fill for moveable supports. You can add supports out of a number of materials. Glue them in place if you want.
Old 10-08-2013, 08:30 PM   #8
Yes I do the same for book shelves and other things. There are various ways to increase the stiffness of a shelf member...the challenge is make these ideas scalable to something small and minimalistic like a medicine cabinet.
The only idea that came to mind that may work is to drill holes on the back side of the medicince cabinet and put intermediate pins along the 33"+ length.
I am going with frosted glass shelves, have those ordered today.
Receptacle in Medicine Cabinet: Code Compliant? bpSF Electrical 5 08-31-2013 05:13 PM
help with medicine cabinet stash823 Kitchen & Bath Remodeling 7 02-13-2013 02:03 PM
Bathroom medicine cabinet and light rough in miamicuse Kitchen & Bath Remodeling 1 05-02-2012 08:30 PM
glass shelf and medicine cabinet height amakarevic Carpentry 4 11-27-2011 08:29 AM
