Measuring Woes - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-07-2013, 07:02 PM   #1
Measuring woes
Hi all. I've been looking around here for a bit and like the forum so far. Normally someone's first post would be about an accomplishment or something fun, but not me. Mine is going to be about how much I hate measuring.
I'm one of those guys who have to measure not twice before I cut, but 3, 5....OK 8 times before I cut. I always second guess myself. I hate it. Then I cut and one of two things happen next. I either measure again to make sure I didn't screw up and shock myself that I need to measure again just to make sure I actually did it. Or, I measure again and sure enough I did screw it up.
So, just curious, am I the only one, or are there others like me? What are your measuring woes? What do you hate about measuring? What issues to you have when measuring?
Get your frustrations out here.
Riptyde.
riptyde is offline   Reply With Quote
Old 10-07-2013, 07:44 PM   #2
DIY staff
Rewards Points: 7,174
You would hate working around me--I measure an entire room for trim and then go cut it---never a second thought---
But learning how to measure--that is the first thing I need to teach a new guy---maybe you need measuring lessons---
kwikfishron (10-07-2013)
Old 10-07-2013, 08:20 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 56
Been measuring for flooring for 40 years and always write everything down. Write down your measurements as you go, and you should always be right.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-07-2013, 09:03 PM   #4
Civil Engineer
Rewards Points: 4,580
In cabinet building, measuring is often replaced with marking. For example, you need a dozen pieces exactly 12-3/4 inches long. You measure and cut the first one, then use it to mark the remaining pieces. Better precision, better accuracy, absolute repeatability. Beats measuring hands down.
There are entire chapters in fine cabinetmaking books devoted to clever techniques to avoid measuring. Jigs, techniques, methods, all to avoid measuring, since no matter how carefully you measure, there will be errors, many of which are avoidable if you mark instead of measure.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
oh'mike (04-25-2014)
Old 10-07-2013, 09:47 PM   #5
Rewards Points: 3,130
This has nothing to do with measuring. You sound obsessive-compulsive. Do you have this issue with other things in your life??
The Following 3 Users Say Thank You to md2lgyk For This Useful Post:
12penny (10-08-2013), joecaption (10-08-2013), oh'mike (10-08-2013)
Old 10-09-2013, 11:04 AM   #6
Rewards Points: 1,444
If you do use a pre-cut piece to mark the next pieces, make sure you keep using the first one. If you use the last one cut every time the pieces will get slightly longer every cut.
mikegp is offline   Reply With Quote
Old 10-10-2013, 08:20 AM   #7
Lord of Slums
Rewards Points: 1,974
Long time ago a carpenter showed me something. He measured then made a mark. He explained that that mark will always be in the same spot. You want 1/32 less, you can just go from the mark. No need to keep remeasuring.
mj12 is offline   Reply With Quote
Old 10-10-2013, 08:28 AM   #8
PoleCat's Avatar
Rewards Points: 1,646
I learned to use the same tape, never change off between two or more.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-10-2013, 10:35 PM   #9
I built a new bathroom in my house, but I measured about 5 inches shorter than I should have, and after putting the shower in, the toilet didn't fit. Super frustrating! Be sure to write everything down.
kevinhart is offline   Reply With Quote
Old 10-10-2013, 10:44 PM   #10
Renovating My Land Yacht
Rewards Points: 616
My nemesis is stupid fractions. I am from a the metric side of the world and it drives me nuts. 16ths, 8ths etc. Finally broke down and bought a metric tape measure. Mucho happier now. Even got the hubby using it a bit.
I also learned something interesting couple of weeks ago hanging drywall. My house is built with 2 x 4's....as in REAL 2 x 4's - 2 inches by 4 inches. That extra 1/2 inch comes in handy sometimes.
Robyn
forcedreno2012 is offline   Reply With Quote
Old 10-10-2013, 11:00 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,194
ryptyd....don't feel bad....I'm right there with you.....
One of my common mistakes......say I have a measurement that is 68 7/8". I'll mark the 67 7/8" mark.
So...yea...I measure twice....
I also write measurements down on the wall or stud....
One of the hardest tasks is marking holes in drywall before you hang it....you always need some 'slop' in your cuts....and you have to factor in that slop when positioning holes for boxes....
Old 10-10-2013, 11:10 PM   #12
Rewards Points: 380
I don't have to measure 6 or 8 times, but I do have to do it several times. Just because I regularly forget the number between the time that I measured and the time that I get to the saw (or piece of paper I'm writing it on).
The other reason is, like ddawg said, I can look at a measurement that is, for example, 13 & 5/8 but when I go to cut the piece, I'll mix up a couple of the numbers so that I think it's 15 & 3/8. Knowing that this happens, I will usually make myself go back and measure again. Annoying. It's not so bad if it's very quiet here and there are absolutely no distractions.
Mike, holy cow! Do you know how many extra trips to the lumber store I'd have to make if I tried measuring the whole room one time only? Me either, because I could never do what you do.
Barb
gma2rjc is offline   Reply With Quote
Old 10-11-2013, 12:10 AM   #13
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
Robyn
This. Though I am not in the metric world, I have one tape measure that has 16ths on one side and CM on the other side. I found that on a lot of things that I am trying to do precision cuts, I have an easier time using the metric tape than converting fractions in my head. Though, if I did things for a living and used it a lot more, I'm sure the "standard" measurements would be just as easy.
hyunelan2 is offline   Reply With Quote
Measuring for bathroom cabinets Wiscbldr Building & Construction 9 11-08-2011 03:25 PM
Measuring for retrofit windows mday83 Windows and Doors 5 08-14-2011 08:49 PM
Measuring for Vertical Cement Siding Edward1 Building & Construction 0 02-20-2011 05:44 PM
Measuring for replacement windows. adeebdiy Carpentry 5 10-17-2010 10:07 PM
laser measuring tools kerstin Carpentry 3 05-31-2009 09:44 PM
