Measuring For Window Trim - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-09-2009, 08:13 AM   #1
measuring for window trim
I would like to install new window trim around my kitchen window. I'm not sure how to measure for the trim. Any suggestions would be appreciated. thank you
Missaligned is offline   Reply With Quote
Old 12-09-2009, 08:37 AM   #2
MJW
Measure the trim and add a foot. Trim is very inexpensive. Better to have more, than not enough.
MJW is offline   Reply With Quote
Old 12-12-2009, 12:05 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Please don't take offense to this, but if you don't know how to measure for it, how do you propose to install it?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 12-12-2009, 12:41 AM   #4
Rewards Points: 6,652
It measures the same way, that you measure for a picture frame.
Old 12-14-2009, 02:20 PM   #5
Yeah, for sure. Better to throw away a couple feet of trim than to end up 2 inches short!
When it comes time to put it on, don't measure. Hold the piece of wood up to the window and mark it where you want it cut -- you eliminate two opportunites to mis-use a tape measure that way. I put on the two sides first, and then set the top upside down on the sides and mark it for length.
I like to use a 1/4" reveal on window trim. I set a combination square to 1/4" and make marks on the jambs.
pyper is offline   Reply With Quote
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
Measuring trim for mitered baseboard installation abbyqueue Carpentry 3 07-28-2009 01:54 PM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 02:19 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 01:16 PM
