Math For Egress Window Clearance - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-25-2007, 06:10 PM   #1
Math for egress window clearance
I'm cutting an egress window into my foundation and am trying to figure out the difference between rough sill height and finished sill height. I figured about 4". Is that about right? (I need to know because the floor to bottom of the finished sill can be only 44" with a max 7" riser.
Thanks.
digthisbigcrux is offline   Reply With Quote
Old 03-29-2007, 09:30 PM   #2
It's basically just math.
Figure you will frame wood 2x around the perimeter of the window.
Then you want at least 1/4 inch space between the window framing and the window jamb bottom.
So add 1 1/2 inches for the framing and add 1/4 inch plus the actul thickness from the bottom of the jamb to the top of the sill, and thats the number that you subtract from 44" to get a location to cut the rough opening.
Keep in mind that 44" is max. height so if in doubt go a little lower than you think you need to be.
Good luck.
jiggyjack is offline   Reply With Quote
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 06:19 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
I blew it on the mesurements.Vinyl window Doug Crf Remodeling 6 03-29-2007 10:06 PM
Window jamb helpless handyman Carpentry 11 08-03-2006 12:45 PM
