-   -   Math for egress window clearance (http://www.diychatroom.com/f2/math-egress-window-clearance-7361/)
digthisbigcrux 03-25-2007 07:10 PM
I'm cutting an egress window into my foundation and am trying to figure out the difference between rough sill height and finished sill height. I figured about 4". Is that about right? (I need to know because the floor to bottom of the finished sill can be only 44" with a max 7" riser.
Thanks.
jiggyjack 03-29-2007 10:30 PM
It's basically just math.
Figure you will frame wood 2x around the perimeter of the window.
Then you want at least 1/4 inch space between the window framing and the window jamb bottom.
So add 1 1/2 inches for the framing and add 1/4 inch plus the actul thickness from the bottom of the jamb to the top of the sill, and thats the number that you subtract from 44" to get a location to cut the rough opening.
Keep in mind that 44" is max. height so if in doubt go a little lower than you think you need to be.
Good luck.
