Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-09-2012, 06:50 PM   #1
material calculation
Is there a material calculation formula for rough framing of a new construction home. The home is 3400 sq ft with a full unfinish basement (13 course). The home will also have 17 ft ceilings in great room area other ceiling will be 9-10 ft.
jbillups is offline   Reply With Quote
Old 02-09-2012, 07:06 PM   #2
Disabled wood vet
titanoman's Avatar
Not really. The lumberyard will gladly figure it for you.
titanoman is offline   Reply With Quote
The Following 2 Users Say Thank You to titanoman For This Useful Post:
Willie T (02-09-2012), woodworkbykirk (02-24-2012)
Old 02-09-2012, 08:06 PM   #3
You do understand that's going to be a huge waste of lumber and sky high HVAC cost with those odd ball sizes and high ceilings.
Old 02-09-2012, 08:44 PM   #4
What would be a more reasonable ceiling height; 12-13ft? for a high great room? Is 9 ft ceiling odd ceiling heights?
Old 02-09-2012, 09:29 PM   #5
Disabled wood vet
titanoman's Avatar
9' is a standard height (actually 10' is too) and I built a lot of houses with 18' great rooms. There's nothing wrong or unusual about that.
Old 02-09-2012, 10:20 PM   #6
Standard lumber comes 8, 10, 12, 14, 16 lenghts.
Sheetrock comes in 4' widths so any some you can design around that your going to save materials and money.
You would be far better off spending the money to have someone design this for you to avoid making mistakes.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
mae-ling (02-24-2012), woodworkbykirk (02-24-2012)
Old 02-09-2012, 10:37 PM   #7
Disabled wood vet
titanoman's Avatar
And 9' studs.
And 18' and 20' - standard.
And 54" wide sheetrock (x4=18').
Old 02-09-2012, 10:37 PM   #8
retired union carpenter
Send a message via Yahoo to coupe
the "material calculation formula for rough framing of a new construction home" is in the design, blueprints, and spec sheets for the home. if you can't figure the materials needed from those? I'm afraid building it yourself is out of your league?
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
The Following User Says Thank You to coupe For This Useful Post:
Old 02-09-2012, 10:39 PM   #9
Disabled wood vet
titanoman's Avatar
Good point.
Old 02-09-2012, 11:06 PM   #10
Framing Contractor
I've been doing framing material lists for almost 30 years. It's not something you figure out overnight. You have to start from the top of the foundation and up til the last piece of wood on the house. You have to know every single piece of wood that goes into the house.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-24-2012, 12:21 AM   #11
This might be the case but if he is willing to go through with it then so be it, right?
diyjohn1234 is offline   Reply With Quote
Old 02-24-2012, 05:16 PM   #12
journeyman carpenter
woodworkbykirk's Avatar
another thing is, you also have to allow extra material for temporarily bracing walls and backing for fixtures.
with this though some of the bracing can be used elsewhere once walls are locked in, though this wood can become warped from the tension of holding walls plumb. most blocking can just be offcuts but occasionally you will need extra lumber just for this depending on the design of the house. many local track home builders are notorious for not allowing for just this, they account for the least amount of material possilble to build the house and dont allow for bracing.. if your the framing contractor you have to buy that extra wood out of your profit margin... this is why so many trac home builders bankrupt subtrades so often here and why i stick to high end renovations and custom home building
woodworkbykirk is offline   Reply With Quote
Old 02-24-2012, 07:18 PM   #13
My biggest complaint with getting a package, they rarely send enough if any bracing
mae-ling is offline   Reply With Quote
Replacing underlayment in entire house...what material to use? Dave321 Flooring 23 12-23-2011 03:38 PM
Load Calculation Fee - HVAC Contractors Please DIYerIT HVAC 2 07-30-2011 05:39 PM
Gap-filling material for r.r. tie sidewalk Hi Country Home Building & Construction 1 05-28-2011 09:58 PM
Newbie: Soffit NFA calculation + what material for vent? Tranch Roofing/Siding 5 07-19-2009 06:43 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
