Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-20-2011, 02:11 PM   #1
Matching ceiling texture. please help!
Can anyone tell me how to match this ceiling texture? It doesn't have to be perfect. I would just like it to look pretty similar. Obviously I'm not a professional. I fixed a collapsed section of a plaster and lathe ceiling in a 100 year old house with a section of drywall and then taped and mudded the edges. Now I need to match texture. Thanks for your help!
wayne937 is offline   Reply With Quote
Old 10-20-2011, 03:46 PM   #2
Looks a bit like broken leather which is done by putting a plastic bag over the stippler and running it over the Artex. Artex is like handwriting though, and everyone seems to have a slightly different pattern.
stuart45 is offline   Reply With Quote
Old 10-20-2011, 05:52 PM   #3
Framing Contractor
I think that is just a homeowner stomp with no knockdown. You use a roller to apply the thinned mud, then use a stomp brush to create the pattern. Looks like they mixed it a little thin, you can experiment with the thickness a little. Be sure to roll into the existing a little and this will help blend it in.
sixeightten is online now   Reply With Quote
Old 10-20-2011, 09:35 PM   #4
Stuck in the 70's
Blondesense's Avatar
I'm no expert, but I had to do a similar repair on the bathroom wall of our previous house. I got some cardboard from the grocery store and experimented a bit until I found something I could live with.
The Following User Says Thank You to Blondesense For This Useful Post:
sixeightten (10-20-2011)
Old 10-20-2011, 10:16 PM   #5
looks like a stipple brush was used....can get at hardware store or I have used a paint brush to dab and blend texture?
ben's plumbing is online now   Reply With Quote
Matching texture - is this the truth..? findlay70 Drywall & Plaster 6 05-26-2011 12:38 AM
Roll on ceiling texture Chayvo Drywall & Plaster 1 01-28-2011 09:51 AM
how to light sand texture ceiling mtom01 Painting 4 03-13-2010 01:11 AM
Ceiling Texture Matching MJBhoya Painting 3 02-08-2009 11:04 PM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 04:50 PM
