Masonry Anchors - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-02-2004, 08:02 AM   #1
Masonry anchors
Hi,
I'm about to attach a small, wooden (4'x8') front entry enclosure to a concrete block bldg.
Any recomendations on fastening?
tomkae is offline   Reply With Quote
Old 04-02-2004, 05:28 PM   #2
Guest
Guest
Posts: n/a
Tap-Cons, or Expansion anchors.
Old 02-27-2009, 12:29 AM   #3
THEE BEST, is Simpson SET2 epoxy. Tap cons and other expansion anchors are a pressure/friction reliant system by expanding inside the drilled hole. If you use epoxy in the hole, then insert the bolt or post anchor, it will take an atomic bomb to get it out or loosen. Epoxy is the ONLY anchor system approved by building depts. and engineers in California for retrofitting anchors. The concrete breaks before the bolt will come out.
allencd@cox.net is offline   Reply With Quote
Old 02-27-2009, 07:44 AM   #4
Registered User
Termite's Avatar
this is a five year old thread
Old 02-27-2009, 03:03 PM   #5
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
don't worry termite, i'm sure the OP is still looking for the correct answer.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Wall Anchors ffgus Electrical 3 10-17-2011 11:16 AM
Requirements for Sill anchors and ledger boards? sandyman720 Building & Construction 7 08-20-2007 06:56 AM
Cheaper masonry alternatives to brick? Jemo Building & Construction 9 05-18-2007 12:31 PM
Sealing above steel lintel in masonry building? mkchicago Building & Construction 1 02-28-2007 07:23 PM
Suggestions for wall anchors MIKEGOUGH1 Building & Construction 1 12-06-2006 09:23 AM
