On To Masonry - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-26-2009, 10:21 PM   #1
On to masonry
I own a brick home and have noticed a problem with the mortar on the side of my house. On the side where the driveway is located, the mortar in between the bricks seems to have washed out in places. Now the joints are recessed a bit to give it depth I guess, but there are clearly places where the mortar looks like it was pressure washed out. I"m sure its weather related because the paint is washed off as well. (The house is painted white) How would I tackle this problem? Any help would be greatly appreciated.
rick32 is offline   Reply With Quote
Old 05-27-2009, 06:08 AM   #2
Sounds like you need repointing. Not a DIY job unless you are a mason. The old crumbling mortar needs to be ground out and new mortar pushed into the openings. The old mortar needs to be removed roughly 3 times the size of the joint, so a 1/2 joint needs mortar removed/replaced 1 1/2" into the joint.
Old 05-28-2009, 10:05 PM   #3
once I get this problem fixed, would it be wise, beneficial or just crazy to dryloc the exterior of my house?
Old 05-29-2009, 05:50 AM   #4
Not usually needed. Proper mortar joints should last a long time. Those treatments rarely last more that a year or two.
Old 05-29-2009, 07:45 AM   #5
Rewards Points: 356
Dryloc on exterior brick can lock in moisture and may cause a whole new set of problems. I see many painted brick homes that have the face of the brick (not just the paint) flaking off. I often wonder if this is caused by the paint or did the HO paint because the brick was flaking???
Rege
RegeSullivan is offline   Reply With Quote
Furring on Masonry Borges Carpentry 4 05-14-2008 04:41 PM
What type of metal to flash chimney and masonry wall? Max1119 Roofing/Siding 6 05-03-2008 05:58 AM
Cheaper masonry alternatives to brick? Jemo Building & Construction 9 05-18-2007 12:31 PM
Sealing above steel lintel in masonry building? mkchicago Building & Construction 1 02-28-2007 07:23 PM
