Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-29-2012, 02:48 PM   #1
making straight lines
Hello,
I started working on aluminum recently and I'm finding difficulty making straight line in a short time.
Is there a tool to ease the process ( for centerlines and other distances )?
Thanks.
A.Ma is offline   Reply With Quote
Old 12-29-2012, 03:09 PM   #2
JOATMON
ddawg16's Avatar
A big T-square.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 12-29-2012, 03:10 PM   #3
Little more detail on exactly what it is your working on would help.
Alumiunm plate, coil stock, siding ECT.
What have you been using to do it?
Old 12-29-2012, 03:14 PM   #4
Originally Posted by ddawg16 View Post
A big T-square.
Thanks, I will try that
Old 12-29-2012, 03:18 PM   #5
Alumiunm blocks and plates. I was using a ruler ( making dots and connecting them! ).
Old 12-29-2012, 03:19 PM   #6
Framing square, speed square, Tri Square, sheetock square.
Old 12-30-2012, 01:19 AM   #7
yea rulers wont be good because if its not level it wont come out right. source: personal experience:P
federer is offline   Reply With Quote
Cutting lines from well to pump tibberous Plumbing 0 06-27-2011 10:40 PM
Getting the first line of laminate straight stevenson66 Flooring 5 11-12-2010 01:00 PM
making a good straight cut or paint line ckr31 Painting 5 10-15-2010 05:08 PM
Make them grow straight cprao Landscaping & Lawn Care 9 07-05-2010 04:20 PM
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 06:02 AM
