Making A Mount - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 10:22 AM   #1
Making a mount
Hi,
I would like to make a mount for my LCD monitor since there aren't any mounts here.
I want the mount to go up and down, left and right, far and close.
This one: here is easy to make, since gravity has nothing to do with it.
But if I want to make a similar one that also goes up and down, I won't be able to simply copy the way it moves left and right, because gravity will make the face of the monitor go all the way toward the ground. So, what can I do? How can I make it stop where I want it to stop.
I hope what I'm saying is clear, if not I'll try my best to explain. Thank you.
wajed is offline   Reply With Quote
Old 01-31-2011, 11:00 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Ayuh,... With either springs or tensioning bolts...
Bondo is online now   Reply With Quote
Old 01-31-2011, 11:11 AM   #3
As I've never worked with these, I don't know how the idea be implemented.
Can you direct me to a video or any type of illustration?
Old 01-31-2011, 12:14 PM   #4
Rewards Points: 5,336
Originally Posted by wajed View Post
Hi,
What do you mean by, "I would like to make a mount for my LCD monitor since there aren't any mounts here."
Where are you that you can't have one shipped to you?
If that's an issue, then it would be a good idea the mention what you are mounting and it's weight. Do you realize that a monitor has a specific mounting detail you need to match?
Ron
Old 01-31-2011, 01:00 PM   #5
Ron
I live in Palestine - Gaza, which is near Egypt.
Shipping a mount will cost me about double the mount price itself, because mounts are heavy.
Making my own mount will even suit me better.
Anyway, I'm mounting a 22" monitor, maybe 5 Kilograms is the weight.
Yes I realize that a monitor has a specific mounting detail.
I will look more on the details later, the main thing I'm trying to solve is what I mentioned in the original post.
Old 01-31-2011, 01:12 PM   #6
Base the design on a scissor jack for a car. The pivot points would have wing nuts you tightened at the height you want. You just need a weighted base to counterbalance the monitor.
Ron
Old 02-01-2011, 02:22 AM   #7
@Ron: I can't imagine it really, but I'll try to research on that.
@Bondo: can you tell how the springs thing would work?
Old 02-01-2011, 06:23 AM   #8
Check out this link:
http://www.engineersedge.com/mechani...issor-lift.htm
Ron
Old 02-01-2011, 07:23 AM   #9
But that won't work since I need to put the arm in the wall, not on the floor. Moreover, it will take a lot of space and will be overly huge.
Please see this video: (3:15-3:20)
You will see springs used, but I don't know how these springs will exactly work, how they will be connected, etc...
Old 02-01-2011, 10:05 AM   #10
A good idea has come to my mind. I can find used office chairs (which have adjustable heights) and take the gas spring used (I think they are gas springs, whatever they are they do the job.)
The question is, they are very strong! It will be hard for me to pull them down (compress them,) so is there a way to lower their strength? (maybe lowering the amount of gas will do it. But how?)
Old 02-01-2011, 11:16 AM   #11
Lemme make it
Renate's Avatar
So, you're basically looking to make something like one of these:
http://www.ergonomicbusinesssolution...roup.asp?grp=6
Renate is offline   Reply With Quote
Old 02-01-2011, 11:20 AM   #12
Yes. And as I said before they are not available here.
Ceiling Fan Surface Mount to Drop Mount hbv2020 Electrical 1 02-20-2010 08:24 AM
Plasma TV Mount problem - one of the 4 screws cannot hit a stud..... wasserkool Home Theater 4 01-05-2009 08:24 PM
TV mount on drywall/metal studs? drewnyc Home Theater 4 11-11-2008 03:28 PM
How can I mount this? callmedpit Home Theater 8 10-10-2008 11:29 AM
Bracket to Ceiling mount a Wall mount floodlight Ski Electrical 1 06-27-2008 11:18 AM
