Making Inside Doors Not Movable For Baby Security - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-08-2010, 04:41 PM   #1
newer than a newbie...
Rewards Points: 87
making inside doors not movable for baby security
Hi All.
The title might not explain it well, but I was wondering if anyone knows of a practical way to 'jam' doors from moving at all in the interest of our baby's safety? She is starting to get around and we have a few french doors that she's fine to go around, but we don't want her to be slamming them open and shut. We want the door to be 'unmovable in the open position without having to take it out of the hinges.
Any suggestions?
Thanks in advance!
mcvane is offline   Reply With Quote
Old 05-08-2010, 04:52 PM   #2
Old School
Willie T's Avatar
A normal doorstop pushed under the door, straight-on, at the edge, rather than from one side or the other works very well.
Willie T
Old 05-08-2010, 06:43 PM   #3
the Musigician
DangerMouse's Avatar
If you don't mind the hole in the floor, use a sliding bolt latch.
DM
Old 05-08-2010, 06:47 PM   #4
eyehook and hook from door to base
The older I get the better I was
Old 05-08-2010, 06:55 PM   #5
the Musigician
eyehook and hook? please elucidate.
DM
Old 05-08-2010, 07:17 PM   #6
round with screw threads, other part is long hook/latch with an eye hook attatched one screws in door other to base and hook part sits into eyehook. srry dont know how to get pic for you.
Old 05-08-2010, 07:34 PM   #7
the Musigician
I KNOW what they ARE, but how do they hold the door OPEN?
DM
Old 05-08-2010, 10:11 PM   #8
jlhaslip's Avatar
Rewards Points: 1,100
there are mechanisms similar to sliding bolts that use a rubber tip ans a spring in case you can't drill for the sliding bolt style unit.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 05-09-2010, 08:09 PM   #9
Household Handyman
Rewards Points: 1,408
Yep! The old fashioned hook and latch like on Grandma's screen door, only larger. My son/daughter-in-law had this problem in the home they lived in with the first son. French doors he loved to slam shut when he had just started crawling. I installed the eye near the top of the door framing and the hook mounted into the plaster wall with a plastic anchor. I took my daughter-in-laws height into consideration on this. This method worked well for son #2 also. When they sold the home I was prepared to remove the hook and eyes but the new owners had small kids and liked the idea. David
Old 05-11-2010, 11:25 AM   #10
Here is what we used for your situation. We bought this at Menards but I also believe Toysrus has one similar. One end bolts to the door and one to the wall, then you have to push the buttons to release it once its closed. making inside doors not movable for baby security-0511001021.jpg
Cmudr1 is offline   Reply With Quote
Old 05-14-2010, 04:55 PM   #11
Rewards Points: 1,910
here's an example of a brass door bolt.
http://absupply.net/trimco-244b-bott...bolt-2394.aspx
There are other styles available. They seem to be more elegant than hooks or plastic catches.
Making carriage style garage doors Jill General DIY Discussions 16 10-31-2012 07:06 PM
Making a faux pantry/secret door- Need Advice poorenspirit Carpentry 5 03-11-2010 03:14 PM
Making doors tropic home Carpentry 9 11-23-2008 10:43 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
