Making A Hole In The Wall Without A Drill - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 11:36 AM   #1
Making a hole in the wall without a drill
Hi everyone. Can someone please help me? I'm trying to make a few holes (at least an inch deep) in my concrete or brick wall to hang heavier paintings and a large mirror which also carries alot of weight.. I'm really not sure which one it is but I think it's brick since the building is very old and I think that's what they used way back then to separate attached establishments. The wall is covered by about half an inch of sheetrock.
Is there any way to do this without using a drill since I don't own one?
I'd really appreciate your suggestions.
Thanks.
Alan
AlanS is offline   Reply With Quote
Old 08-02-2010, 11:53 AM   #2
Electrician
Proby's Avatar
What size hole are you looking to make? What is the hole for?
FWIW, you can rent hammer drills from Home Depot or other big box stores.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
The Following User Says Thank You to Proby For This Useful Post:
AlanS (08-02-2010)
Old 08-02-2010, 01:03 PM   #3
Living Life
If you don't own a drill, I doubt you would own the other tools available that would pull of the job. My advice would be to go out and get a cheap drill - most pawnshops should have a used one available for cheap - it's really the best tool for the job.
DavidRobinson is offline   Reply With Quote
The Following User Says Thank You to DavidRobinson For This Useful Post:
AlanS (08-02-2010)
Old 08-02-2010, 02:13 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
You can use a star drill and hammer but trying to keep the hole a consistent size will be tough.
Ole Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
AlanS (08-02-2010)
Old 08-02-2010, 06:06 PM   #5
Rewards Points: 5,336
You need a hammer drill for this project. You also need the correct masonary bit and wall anchors. Buy one or rent one or borrow one.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
AlanS (08-02-2010)
Old 08-02-2010, 08:38 PM   #6
Everybody needs an electric drill! There are few jobs that do not require the use of one!
Do yourself a favor and get one. My favorite is a Makita battery drill that I bought in 1987. Its still going strong and i expect that when I'm dead and gone, some lucky soul will be still be using it!
The Following User Says Thank You to Wildie For This Useful Post:
AlanS (08-03-2010)
Old 08-02-2010, 09:08 PM   #7
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Depending on the anchor you are planning to use, a star drill and lump hammer will work, but as others said, life would be a lot easier if you simply rent an electric, or buy a cheap one
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
AlanS (08-06-2010)
Old 08-02-2010, 10:13 PM   #8
Concrete & Masonry
Rewards Points: 576
Ron
Hey Ron, WTH is a "masonary" bit? Never seen one in my life...........
To the OP, a 8-12# sledge hammer should do the trick. No drill, or even electricity, needed.....................
jomama45 is online now   Reply With Quote
Old 08-02-2010, 11:07 PM   #9
Old School
Willie T's Avatar
I'm pretty sure it's a bit a missionary uses to drill holes at a Masonic Lodge.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
jomama45 (08-03-2010)
Old 08-06-2010, 02:47 AM   #10
Rewards Points: 1,092
Yep
No doubt about it. Get an electric or battery rotary-hammer drill. You will love yourself for it. I've used a star drill and hammer, and it is OK, but nothing like a drill. You'll need the drill for the next project anyway. Masonry drill bits look funnier than steel drill bits. They have a carbide wedge stuck in the end, and the twists are more frequent in the shaft. Get a bit that matches your anchors' size, and drill away. Anchors come in various forms, and you'll maybe need a hammer for them, and/or a wrench. GL. j
The Following User Says Thank You to jklingel For This Useful Post:
AlanS (08-06-2010)
Making a small pass through hole for pipes in wall ltkenbo Drywall & Plaster 11 05-27-2010 08:25 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Drilled into metal in wall, now drill bit is magnetized... rehabhell Carpentry 16 02-18-2010 09:07 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
