Making A Hole Through Glass..? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-21-2014, 12:47 PM   #1
Rewards Points: 14
Making a hole through glass..?
I have a side/coffee table that has a frosted glass insert.. I'd like to make a hole in the center large enough to feed through a power cable to a lamp.
The glass appears to be a bit thicker/more robust than a standard pane, can this be done & if so how do I go about it?
Thanks.
GoatBoy is offline   Reply With Quote
Old 03-21-2014, 01:11 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
http://www.amazon.com/s/?ie=UTF8&key..._71nyp38vrm_b\
Use putty to make a dam around where you want to drill and fill with water, that will keep the glass cooler and let the cutter work better. Drill slow.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 03-21-2014, 01:15 PM   #3
Rewards Points: 12,818
Most likely tempered glass, try to cut it and it's going to shatter.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Bondo (03-21-2014), Maintenance 6 (03-21-2014)
Old 03-24-2014, 08:56 AM   #4
Rewards Points: 147
Yep. Unless it was a homemade job with plate glass it's tempered and not doable. You could change to plate glass but that's extremely dangerous. If someone fell on it they could get serious hurt.
Rango is offline   Reply With Quote
Old 03-25-2014, 03:10 PM   #5
Rewards Points: 346
Your only safe option is to have a glass shop cut a piece of glass to size, cut the hole and temper it. Be sure to tell them what you plan to use it for. They will know what thickness to make it.
RegeSullivan is offline   Reply With Quote
The Following User Says Thank You to RegeSullivan For This Useful Post:
de-nagorg (03-25-2014)
Old 03-25-2014, 04:41 PM   #6
Rewards Points: 732
Required by law that any glass used as furniture is to be tempered safety glass. Not drillable, must be bored before tempering.
ED
de-nagorg is offline   Reply With Quote
Old 03-26-2014, 09:11 AM   #7
beverlyLynch's Avatar
This really confuses me. I think you should consider a professional for this. Because this action is undo-able.
beverlyLynch is offline   Reply With Quote
Making a small pass through hole for pipes in wall ltkenbo Drywall & Plaster 11 05-27-2010 09:25 PM
Making conduit hole in raised cement floor Red Squirrel Building & Construction 6 04-28-2010 07:53 AM
Deadbolt too large for deadbolt hole in frame? wysiwyg6000 General DIY Discussions 2 01-01-2010 11:06 AM
