Make A Cabinet Swivel On A Base - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-30-2013, 01:29 PM   #1
Make a cabinet swivel on a base
Hi all...
My wife has a wood cabinet that weighs @ 100 lbs & is 16" x 18" x 5' high. It has 4 legs that make it sit about 6-8" off the floor; they are not removable & I don't want to saw them off to make it flush with the floor. I could in a pinch attach a piece of plywood to the four legs to make it flush with the floor if I needed to, but I'd like to avoid that if I can. She would like for the cabinet to rotate 360 on a base and doesn't want casters.
Any suggestions?
TIY,
Nick
NICKM51 is offline   Reply With Quote
Old 12-30-2013, 01:34 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
http://www.google.com/search?biw=360...72.d3b7WTMZCG4
sublime2 is offline   Reply With Quote
Old 12-30-2013, 01:44 PM   #3
Thanks! I have the typical lazy susan brackets, but I'd really like to try another way of doing this. Not sure I could attach it properly with the metal screws...given the overall weight of the cabinet. I'm hoping I can make something like this work:
http://www.nauticexpo.com/prod/optip...31-281086.html
Old 12-30-2013, 05:06 PM   #4
Rewards Points: 14,306
Posting a picture of this cabinet would be a big help.
Old 12-30-2013, 05:16 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,728
Ayuh,.... Must Have, I'd say,....
I like the lazy susan beain' bracket better than the sailboat hardware,...
Can ya cut the legs off, attach the L/S, then put the legs back on,..??
you'd probably be lookin' at raisin' the cabinet by an inch or two, with the mountin', 'n bracketry,...
Bondo is online now   Reply With Quote
Old 12-30-2013, 05:25 PM   #6
Here's the pic...
This is pretty close to the cabinet, except it's got 4 seperate legs... Naw, can't cut off the legs, but affixing plywood to the bottom will satisfy her...
Hopefully, the pic will post properly; if not, here's the link
http://thumbs1.ebaystatic.com/d/l225...T8z63Cg9XA.jpg
Old 12-30-2013, 05:32 PM   #7
Bondo's Avatar
Ayuh,... That looks like there No support near the center of it, just along the sides,...
Maybe 2, steel(or aluminum) plates, 18"x16"x 1/4" each,...
lay 1 on the floor, the L/S bearin', then the top plate,...
Set the cabinet, 'n it'll only be 'bout an inch or so taller,...
I believe any less than 1/4" thick, they'll bend,...
Old 12-30-2013, 05:37 PM   #8
Thanks!!! Sounds like a good idea - I'll have to see how much it'll cost to do it that way - Hadn't thought of metal sheets...
Old 12-30-2013, 06:33 PM   #9
Rewards Points: 4,274
Seat swivel. Boat shops have a lot of them.
http://www.iboats.com/Garelick-Unive...-view_id.37936
(edit... I see someone else suggested this above. Not a good idea to use screws. Nuts/bolts would be better)
Bob Sanders is offline   Reply With Quote
Old 12-30-2013, 07:18 PM   #10
Thanks for the thought. Only kidding about the nautical thing, of course, but the idea of something similar - along the same lines, if you will, seemed to make sense. Nuts and bolts won't work on this...
Old 12-30-2013, 07:33 PM   #11
MT Stringer's Avatar
Rewards Points: 254
Instead of a swiveling cabinet, you might end up with a teeter totter. Be careful with your design...and good luck.
MT Stringer is offline   Reply With Quote
The Following 2 Users Say Thank You to MT Stringer For This Useful Post:
Live_Oak (01-03-2014), NICKM51 (12-31-2013)
Old 12-30-2013, 07:34 PM   #12
Rewards Points: 2,648
With a 5 foot tall cabinet, it sure seems like that cabinet is going to rock real bad.
And then that cabinet is 24" across corners, so you have to place it 8" away from the wall.
Does not sound like a good idea to me.
SPS-1 is offline   Reply With Quote
The Following 2 Users Say Thank You to SPS-1 For This Useful Post:
Old 12-30-2013, 08:00 PM   #13
Rewards Points: 240
there are rotating displays at retail stores that are bigger than that. find what they use.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Building a block wall - how to make base? tibberous Building & Construction 4 11-26-2012 06:27 PM
Do you make your face frames flush with the cabinet inside and out? noone Carpentry 1 02-17-2012 03:25 PM
Bathroom project: in floor heating, slc and shower base Me xeno Flooring 1 01-20-2012 07:12 AM
Make cabinet hole bigger for warming drawer sophiegirl Carpentry 2 01-17-2012 06:47 PM
Want to make cuts in cabinet walls to put in shelfs humberguy Carpentry 3 07-09-2009 09:07 PM
