Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-07-2007, 04:44 PM   #1
Default Major screw up: Deck stain
1st i tried to remove the old stain with 2700 PSI water pressure..didnt work. Then tried stain remover...didnt work.
Now I can see that I used the wrong stain to cover up.
Question is....is there something else I can apply over this to make my deck look like new?
usaalways is offline   Reply With Quote
Old 07-07-2007, 07:40 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
I'm not sure what your looking for
Don't like the look of the semi-trans?
You could go over it with a solid stain
Solid stains basically look solid, like paint
slickshift is offline   Reply With Quote
Old 07-07-2007, 08:55 PM   #3
the stuff I used looks very dull, and it shows all the spots where I couldnt get the other stain off. Looks very bad, actually.
Old 07-07-2007, 11:22 PM   #4
slickshift's Avatar
Ah...
In that case, it's a job for a solid stain
It will leave a solid color, like paint would
Old 07-10-2007, 04:39 PM   #5
I can attest to how well solid stain works. I am just finishing my fence which was a horrible hideous wreck and had some areas stained, some back to raw wood and the solid hid it all. Now it looks like one consistent colour but you can still get a sense of the grain. From experience, do not use paint as you will end up with a real maintenance mess.
Here's a shot of my new stain and the original boards. You can see the stain covered well and that was only the first coat.
Dusty is offline   Reply With Quote
More On This Topic
Mark Kneskern with Expert Village, and in this clip I'm going to show you how to put the finishing touches on your screen printing project. After you're done with the actual screen printing, and before you iron your shirt, you'll want to look it over for... Read More »
Tips on Stage Fighting Gear
Tips on Stage Fighting Gear by Expert Village
When you're fencing competitively or practicing competitive fencing, just as important as your sword is your gear. Maybe a lot of fencing gear you can get, but you never want to fence without these two items. Your helmet--important for obvious reasons... Read More »
Tips for Foil Fencing
Tips for Foil Fencing by Expert Village
That concludes our basic fencing attacks. Hopefully you have a good foundation to begin the foil fencing. You can find my website at Amyboyle.com and you can also fin additional resources on fencing and tips on gear at www.fencing.net. So I'd like to... Read More »
And now we'll go back to the right, making sure that we've still established that same solid canter, and that we keep the horses straight over both fences. As you jump your horse, you'll probably find that they have one side that they're a little bit... Read More »
How to Stain Wood
How to Stain Wood by Expert Village
One of the very first things you want to make sure of is, that whatever you're using to stain, whatever color, whatever material, is that you stir the material up thoroughly because what happens is, you might have the solids, down in the bottom and then... Read More »
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 09:12 PM
Deck Stain Color idea's flyultralite Building & Construction 0 07-11-2007 04:48 PM
Removing excess deck stain from vinyl siding sleepy23 Remodeling 7 05-16-2007 09:13 AM
How do I remove excess deck stain? McBerry Painting 7 10-12-2006 06:48 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
