Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-11-2012, 06:40 PM   #1
mailbox support
Want to install a 4"x4" treated post into one of the setting concrete mixes to put a mailbox on it. Read numerous how to's to set the post and most of them set the post in concrete. In the diy central section it mentions setting a post in concrete and if someone hits it they may be liable.
gt1935 is offline   Reply With Quote
Old 11-11-2012, 08:05 PM   #2
mailbox support
If you are asking if you would be liable if someone hits it, then no.
It will not do any more damage if it is set in concrete than if it was not. If someone hits it, the post is going to break.
The concrete keeps the post from becoming loose in the ground over time.
spotco2 is offline   Reply With Quote
Old 11-12-2012, 11:48 AM   #3
World's Tallest Midget
Mort's Avatar
mailbox support
Maybe what you're thinking of is when people have their mailboxes repeatedly hit, so they fill a dummy box up with concrete to mess with the vandals?
Setting the post in concrete is the proper way to do it.
Mort is offline   Reply With Quote
Old 11-13-2012, 06:25 PM   #4
mailbox support
I'd fill it with explosives if they kept taking it out....
Evstarr is offline   Reply With Quote
Old Weather Head support connection problem RMCNABB Electrical 2 06-17-2011 05:27 AM
Max horizontal load on vertical basement support beam supa Building & Construction 8 02-27-2011 02:51 PM
Alterative ways to support main beam frizbplaya Building & Construction 8 01-29-2011 12:10 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
