Lvl Microllams - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-21-2007, 06:55 PM   #1
lvl microllams
I had an addition put on and the contractor used 13/4 x 8 microllams spaced 12" on center, spanning 189". My question is this. Can I drill a 3/4" hole thru this beam to run electrical wires through?
Jim
jmjrich@wowway.com is offline   Reply With Quote
Old 11-21-2007, 06:58 PM   #2
Should not be a problem, ask your GC to be sure.
Big Bob is offline   Reply With Quote
Old 11-21-2007, 08:50 PM   #3
robertcdf's Avatar
I would check... But usually microlams are not supposed to be drilled. I am assuming he used these as joists? Used these to span a greater distance with smaller members? Being that they are only joists it is much more likely to be allowed but still should be checked with the GC and/or the local building inspector.
robertcdf is offline   Reply With Quote
Old 11-21-2007, 10:20 PM   #4
remodeling pro
I agree, that since it sounds like they are basically just used a floor joists from the description, there should be no problem. If they were used in a true "beam" situation, they could not be penetrated.
Even in this seemingly "overkill" situation, you are right, best to get the answer from the inspector; his opinion is the only one that matters.
troubleseeker is offline   Reply With Quote
