LVL Installation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-07-2014, 11:14 PM   #1
LVL installation
Hi,
I am wanting to remove an existing load bearing wall the separates my dining room and family room. Can anyone tell me what size LVL I will need for a 28 ft span. The only load on this wall is the roof. There has no second floor nor do i use the attic for storage.
Any help would be appreciated.
cjones10 is offline   Reply With Quote
Old 04-08-2014, 12:07 AM   #2
iminaquagmire's Avatar
Rewards Points: 338
6 18" LVL's through bolted at 3, 6,9, 12, and 15 inches with stainless rod every 12 lengthwise.
No really nobody can give you an answer without knowing your location, and how your existing structure is framed. And its not just taking walls out and putting an LVL in either. That load has to transfer somewhere and that spot also has to be adequately framed and supported at the bottom as well. The safest thing for you to do is get a structural engineer on site.
iminaquagmire is offline   Reply With Quote
Veneer Brick Installation jefsboys Remodeling 3 11-01-2012 06:42 PM
Sewage grinder pit and pump installation leff1rj Plumbing 15 02-04-2011 11:36 AM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
