Lowe's Gave Me Bad Advice! Now How To Fix??? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-25-2013, 10:24 PM   #16
It's flat paint with shark sand...it may be absorbent enough for sealer. The paint label should have said what to use over it. Anyway, I would have let the paint dry a good long time, then seal it if appropriate, then let the sealant dry a good long time before trying to fix it. Some adhesives and probably some coatings could take months to harden under poor conditions. I'd leave it alone for a while. Just keep it clean and dry if possible...but I'm not a pro and I'm out numbered here.
Dorado is offline   Reply With Quote
Old 02-26-2013, 02:48 AM   #17
paper hanger and painter
chrisn's Avatar
Rewards Points: 390
If and I said IF, you can get the crap off without ruining the paint job, this should work
http://www.rainguard.com/index.php?o...hane&Itemid=79
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
Mel6626 (02-28-2013)
Old 02-26-2013, 05:18 AM   #18
Davejss's Avatar
Rewards Points: 772
You asked an $8 an hour clerk for advice......
Davejss is offline   Reply With Quote
Old 02-26-2013, 06:39 AM   #19
r0ckstarr's Avatar
Rewards Points: 2,052
What does the sealer say the dry time is supposed to be? Maybe you're not waiting long enough?
Also, the paint work looks great! Got any pictures with the failed sealer on it?
r0ckstarr is offline   Reply With Quote
Old 02-28-2013, 07:38 AM   #20
Arrow
Thanks for all the advice. I have been mopping it every night with Simple Green and Dawn. So far it is slowly removing the stickiness. I have scoured a bunch of paint off, but that I can fix easily. The manufacturer H&C responded back again and confirmed that degreaser and elbow grease should eventually remove it. They further suggested these products to seal it:
H&C Concrete Sealer Wet Look
http://www.hcconcrete.com/products/c...look/index.jsp
H&C Concrete Stain Solid Color Water-based
http://www.hcconcrete.com/products/s...tain/index.jsp
Any thoughts if this is appropriate?
Mel6626 is offline   Reply With Quote
Old 02-28-2013, 08:05 AM   #21
Gymschu's Avatar
Rewards Points: 832
Anytime you SEAL concrete it's a crapshoot. My local SW store manager applied an epoxy to an outdoor patio.......It looked awesome........for about 6 months. Concrete, even older concrete, has moisture migrating from underneath to the surface......it is not a lot of moisture, but, it is moisture. Anyway, long story short, the top portion of his patio just started POPPING, I mean chunks began to pop off because the moisture got trapped between the top of the concrete and the epoxy coating. Not saying this is exactly like your case, but, do your homework & make sure you don't seal in unwanted moisture.
Gymschu is online now   Reply With Quote
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
Mel6626 (02-28-2013), oh'mike (03-01-2013)
Old 02-28-2013, 08:20 AM   #22
ccarlisle's Avatar
Not only that (above) but concrete has a major pH-associated problem with it that only certain paints can handle; you say "BM exterior flat"...that says nothing to me - apart from a paint that isn't designed for concrete applications. See, concrete is very alkaline and needs a paint that will withstand that attack from within.
But you saw paint there before and just assumed more paint would do now; wrong. Then you went ahead and concocted some scheme to paint and seal concrete. Wrong again. Then you went to Ace or Lowes or soemwhere and put your trust in them to settle your sealant nightmare. Wrong again. Then you asked the manufacturer...well that was the closest thing to a right idea you've had all along; trouble is now you're throwing good money after bad. Sure they'll sell you something - but whether or not that something will apply/solve your situation isn't their concern.
IMO it was a bad idea from the start. But too late for advice now; so sit back and blame the world for your problem, but don't come here for 'how-to-fix-it" advice for free. LOL
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
The Following 2 Users Say Thank You to ccarlisle For This Useful Post:
Gymschu (02-28-2013), Nailbags (03-07-2013)
Old 02-28-2013, 08:42 AM   #23
Ccarlisle- while I understand your position, I don't quite agree. If this is not a forum to get free advice- then what is it? Don't persecute me for coming to get advice as this is the exact purpose of this, no?
My concrete was previously painted by the builder 1 year ago. I bought a stencil and Benjamin Moore was the recommended paint by the stencil manufacturer based on consistency. When going to a home improvement store and asking questions from not a cashier, but a person specializing in that department I HAD a reasonable expectation that they knew a little more than myself in that particular subject. I am not a professional so I HAVE to rely on information from others about home improvements. I have to trust that they are steering me in the right direction. Clearly this backfired.
Maybe painting my patio WAS a bad idea. But guess what? It's my problem to deal with. I can accept that responsibility. But I'm just trying to salvage my hard work. If you don't don't want to help people, which is the premise of this forum I presumed, then don't chastise me for my mistakes. And by all means don't spend your time replying to my self-induced problem.
Again, thank you to all the helpful advice I have received from here. I truly appreciate it. While maybe it's too late to do things the proper way, I may still end up with a comparable result if I'm lucky thanks to all of you.
Old 02-28-2013, 09:10 AM   #24
ccarlisle's Avatar
I tell it as I see it - and I don't apologize for that. Truth hurts sometimes.
Old 02-28-2013, 09:02 PM   #25
r0ckstarr's Avatar
The easy way or the hard way, it's a learning process one way or another. I've done my share of both and still counting. Good luck with how your concrete turns out. I'd be curious to know what it looks like when you've finished.
Old 02-28-2013, 09:29 PM   #26
I will update once I have something meaningful. I'm still in the process of degreasing. Trying Super Clean degreaser now. I called Rain Guard and got some advice from them. They were super helpful and recommend their waterproof product once it get the other product removed. Also explained why the other product failed. I am going to wait several days after the last mop before I "seal" it. I tried to take pics of the floor in its current state but it looks normal because the product left behind still has settled into crevices. So not much point just yet. My persistence will pay off and I will post pics
Old 02-28-2013, 09:41 PM   #27
never ask or listen to advice from amyone in a blue or orange apron. if you haven't noticed the cashiers in those stores are also the specialists that you will find in the various departments. its a learning process and i am sorry you had to find out the hard way, but i am sure you won't make the same mistake again. good luck with fixing it, hope you don't have to repaint the whole thing.
Old 02-28-2013, 11:08 PM   #28
Rewards Points: 282
richard
jcrack_corn is offline   Reply With Quote
The Following User Says Thank You to jcrack_corn For This Useful Post:
Mel6626 (03-01-2013)
Old 03-01-2013, 06:15 AM   #29
Rewards Points: 125
Yikes, sounds like someone is mid-winter cranky
Mel is doing noble work here, scouting ahead of the pack to find one more way not to do something, signaling back "Don't come THIS way fergawdssake!!"
ThatDaveGuy is offline   Reply With Quote
Old 03-01-2013, 08:26 AM   #30
Rewards Points: 5,974
Oh great another pissing contest. I thought our thing here was to help someone who made a mistake or asked a question, not nail them to a cross. I really can't figure out why so many come here and never return. I realize there are going to be different opinions-and remember opinions are like rear ends everybody has one and most of them stink-and different ways to do things that's part of it. Give it your best shot then let the poster pick whice one they think will work for him or her.
And don't come here for advice for free??? what the hell is this forum for?
The Following 4 Users Say Thank You to ToolSeeker For This Useful Post:
Dave Sal (03-03-2013), drtbk4ever (03-04-2013), jomama45 (03-01-2013), r0ckstarr (03-03-2013)
Tags
concrete , protector , sealer , stencil
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Solution for Bad Advice - Latex on Bookcase greenthumb General DIY Discussions 8 08-16-2010 05:58 PM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 11:02 AM
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 08:40 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
