Lowe's Gave Me Bad Advice! Now How To Fix??? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-25-2013, 10:02 PM   #1
Arrow
Lowe's gave me bad advice! Now how to fix???
I stenciled my patio concrete with exterior flat Ben Moore paint. It came out amazing after many hours of blood, sweat, and tears. I went to Lowes's to purchase a sealer to protect my artwork. They sold me H&C Concrete and Driveway Protector and some shark sand to give it some grit to prevent slips. I was looking for something more matte than glossy. Well I applied this product and it is not the result I wanted. After 3 days it is greasy, tacky, and slick. This is clearly not right. I called H&C and they advised me to mop with a degreaser or Simple Green. They also emailed me and told me my best hope is to strip it with Soy Gel . I refuse to strip it and lose my stenciling! I mopped it several times tonight with Simple Green and so far nothing.........except some spots of lost paint. Please advise me how to get this protector off enough so that I can seal it properly. And what product should I use to seal it? I have faith it can be fixed! (Photo pre-sealant)
Mel6626 is offline   Reply With Quote
Old 02-25-2013, 10:13 PM   #2
Rewards Points: 13,300
Exactly which type of paint did you use?
Reguler house paint is just never going to hold up on concrete.
Old 02-25-2013, 10:18 PM   #3
It was Benjamin Moore Ben exterior flat. I was limited to what paints I could use for the stenciling. It's precisely why I want to seal it to protect it.
The concrete was painted when it was built about 1 year ago and didn't have any issues with the paint not holding up yet.
Old 02-25-2013, 10:18 PM   #4
I'm thinking isn't anything that will strip the sealer but not the paint.
what about just going over everything with a different product that has a matte finish?
j-easy is offline   Reply With Quote
Old 02-25-2013, 10:19 PM   #5
DIY staff
Rewards Points: 7,174
Wow---that looks great------It's to late now, but the Benjamin Moore dealer would have had a better chance of advising you correctly------
Fine looking work----just wonderful----
Old 02-25-2013, 10:27 PM   #6
Is there a proper sealant out there that I could just apply over this? I really am very angry at Lowe's for selecting the wrong product. I would rather a salesperson say " I'm not sure" than ruin all my hard work.
Old 02-25-2013, 10:31 PM   #7
DIY staff
I suggest you go to the Benjamin Moore dealer and ask ---those folks have saved my hide on several occasions----bring pictures---and a sample board if you have one---you may want to brush on some of the bad sealer,too.
this way they can experiment--
Old 02-25-2013, 10:34 PM   #8
Floor Installer
sam floor's Avatar
Rewards Points: 154
Lowes gave you bad advice?....you and a million other people.
sam floor is offline   Reply With Quote
Old 02-25-2013, 10:34 PM   #9
MarginallyQualified
Rewards Points: 2,464
Polyurethane will help but NOTHING will do what you want.
Old 02-25-2013, 10:34 PM   #10
Msradell's Avatar
Rewards Points: 132
The problem is that concrete sealers are designed to soak into the concrete. You paint has already sealed the concrete service, so the sealer cannot penetrate. That's the reason the sealer is not drying. I'm afraid it's going to have to be removed. You are probably going to end up using something other than concrete sealer because of the paint.
Msradell is online now   Reply With Quote
Old 02-25-2013, 10:37 PM   #11
Deck Staining Pro
bigchaz's Avatar
Putting more sealer on top is going to increase risk of product failure, you don't have any concrete for it to bond to anymore or soak into. If the previous sealer isnt cured the new sealer will be basically filmed on top which is not how it is meant to work
Charlie Soden
Apex DeckSavers
NC Deck Powerwashing, Deck Cleaning and Staining
"Bringing New life to Old Wood"
bigchaz is offline   Reply With Quote
Old 02-25-2013, 10:47 PM   #12
I'm going to try to keep mopping it in hopes that it returns to the previous state after I painted it. Looks like I will return to Ace Hardware to find something that I could possibly seal it with to protect it, barring the tackiness comes off. H&C claim the protector is just (semi)dried on top since the paint prevented it from absorbing (so they say) and this gives me hope with some elbow grease I can get it off.
Old 02-25-2013, 10:57 PM   #13
Whatever you do do not use poly as suggested!
Old 02-25-2013, 11:02 PM   #14
yea polyurethane would get yellowed by the sun.
maybe polycrylic though?
Old 02-25-2013, 11:05 PM   #15
The UV will cause any poly to fail.
Tags
concrete , protector , sealer , stencil
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Solution for Bad Advice - Latex on Bookcase greenthumb General DIY Discussions 8 08-16-2010 06:58 PM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 09:40 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
