Lower Level Insulation - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-09-2011, 12:43 PM   #16
fire angel's Avatar
OK I have all my insulation installed and am ready for drywall. Any special drywall that I need to use or anything else that I need to know. Thank you for the help!
fire angel is offline   Reply With Quote
Old 02-09-2011, 01:02 PM   #17
Registered User
Rewards Points: 4,888
Make sure there are no voids behind/between the insulation as cc pointed out, convective loops.(no dead space)
Insulate the rim area with rigid foam board then batts, air sealing the foam board first. http://www.buildingscience.com/docum...m-at-rim-joist
Use the ADA when installing the drywall to prevent any air getting to the concrete wall; http://www.buildingscience.com/docum...wall-approach/
Hold the drywall up 1/2" from the slab to prevent wicking of moisture. Use a sill sealer under the frame wall bottom plate for a thermal/capillary break, or at least caulk along the joint of slab/plate for an air seal;http://www.greenbuildingadvisor.com/...-building-code
Gary
need heat suggestion for lower level dallison HVAC 10 01-03-2015 09:10 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 09:19 AM
2x4 Exterior Wall Insulation stubits Building & Construction 4 03-19-2009 08:03 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
