Low Voltage Thermostat Wiring - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-14-2009, 01:25 PM   #1
Low voltage thermostat wiring
I have a line voltage thermostat controlling several baseboard heaters(220 volt). I would like to install a low voltage digital thermostat in its place. What do I need to do?
dirtpig538 is offline   Reply With Quote
Old 02-14-2009, 01:37 PM   #2
Remodeling Contractor
you would need to rewire the thermostat box bringing the wires into a new accessible junction box. Then use a relay to provide the 220V with a 12V contactor. but wire would you ever want to do this. You can get line voltage programmable thermostats with digital reading that can be controlled via the internet cheaper than this step at htttp://www.smarthome.com
Old 02-14-2009, 01:48 PM   #3
Ok, thanks Bob, I will look into that.
Remote sensor for line voltage thermostat? hbridge HVAC 7 07-06-2012 04:42 PM
Honeywell Thermostat Wiring Differences DavidHwang HVAC 16 01-28-2012 03:11 PM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 08:04 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
