Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-25-2005, 12:21 AM   #1
Meg
Losing heat!
Our windows are really old and they rattle and are in a way too small for their frames. I think this is where we're losing all our heat-- once, we had it turned up to 90 and the actual temperature of the house was 72. I stuffed plastic in all the gaping crevices and the temperature dropped 4 degress!
What do I do?
Meg is offline   Reply With Quote
Old 11-25-2005, 01:36 AM   #2
Losing heat!
Actually 90 degree on the thermostat is when it's supposed to trip off when room temp is 90.
What you should do is install new energy efficient windows.
JustaFramer is offline   Reply With Quote
Old 11-25-2005, 09:30 AM   #3
Losing heat!
Meg,
Until you can get new windows installed, a "band-aid" solution is to get some heavy plastic sheeting and staple it to the window frame on the outside of the house. While stapling it on, pull it as taught as you can so it wont be flapping around in the wind then staple some thin wood strapping on where you have stapled the plastic. This just stops the plastic from being pulled out of the staples if it's really windy. I would also think that if your windows are really old, they are only single glazed so the plastic gives you that air space although not to the same effect as double glazed windows. You could also apply some duct tape on the inside covering any gaps between the window and the frame. I admit that this is a cheap and nasty way of doing it, but if you can stop those drafts, it will help somewhat. The down side is, on the next mild day when you would like to air out a little bit, the window is sealed. As Justaframer says, the furnace will run until the temp reaches what it is set at and in your case it could be 24 hours a day. Lots of $$$$
If your house is old, the windows might not be the only culprit but thats for another discussion....see to the windows for a start.
'Andyman is offline   Reply With Quote
Old 12-29-2005, 01:58 AM   #4
Losing heat!
Meg
Is the house owned, or rented? Is it freezing temperatures outside until April or so, as is typical for 80% of the country, where crazy people live? (jk)
You have lots of options, form simple to complex and costly. I suggest however, that all are money savers. You are paying a steep price as it is, just to the utility company, as you well know, once a month!
Replace the windows, caulk and seal the windows, insulate the outside walls, and more can all be done. The caulk and seal drill is going to be included in all answers. Generally, it cannot be done under 40F.
MarkH10 is offline   Reply With Quote
Old 12-29-2005, 06:24 PM   #5
2nd half
Losing heat!
Meg,
Go to H. Depot they have kits for the insides of windows to seal out the cold and keep your heat in which will do you till spring or you replace windows if in fact you plan to do so.
Joe
jmic is offline   Reply With Quote
Old 01-03-2006, 01:15 AM   #6
Commercial Roofing
AaronB's Avatar
Losing heat!
Also, try stuffing insulation between window frame and wall framing then re0installing the window trim. This will cut down on buku airflow. Then do the plastic if you cannot afford the windows just yet.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
heat wont come on with t-stat in auto wahanks HVAC 1 11-22-2006 02:55 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
heat pump not working kyleGR HVAC 2 05-30-2006 03:35 PM
