Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-21-2006, 05:44 AM   #1
Loop Roller
Can anyone explain how to use a loop roller?
A friend wants to put some texture on his ceilings to hide small imperfections but is not sure if the loop roller is used for paint or if he can use joint compund with the roller.
Can joint compound be used with the loop roller?
If so, how is it done?
How do you use the loop roller to apply texture paint?
thanks
redline is offline   Reply With Quote
Old 03-21-2006, 09:34 AM   #2
Electrical Contractor
Loop Roller
Not sure how to use it for texture paint, but I did my basment with one.Just dip it into the mud like a paint roller and roll the ceiling. Stay in the same direction.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 03-21-2006, 08:27 PM   #3
Loop Roller
thanks
How do you use a loop roller? redline Painting 8 04-02-2013 10:05 AM
loop vent or auto-vent amakarevic Plumbing 4 08-21-2007 01:28 PM
Boiler Primary Loop Choices Mike Warner HVAC 7 07-16-2007 11:01 AM
Gravity hot water loop for instant hot water at tap ricgail Plumbing 4 11-17-2006 05:59 PM
how to make a pressure balancing loop gib7464 Plumbing 1 03-25-2006 09:31 PM
