#1 |
Looking for compacting material
Was not sure where to post this so I went to general discussion.... I am looking for some material (fairly cheep) that i can put down and compact to get a solid fairly smooth finish. It does not have to look pretty.
The area I want to cover is under a porch so is not exposed to weather and will only be used for storage. I would like something that i can sweep or use a blower on that will not turn into a dust storm. Any ideas what can be used that would compact well? and not allot of $$$$ joe |
#2 | |
Looking for compacting materialQuote:
Ron |
#3 |
Pretending to be Retired
What about heavy plastic sheeting or a tarp? Or maybe treated plywood?
#4 |
I do not want to use wood, and want something more durable then a tarp. The dirt is very compacted as it is but just wanted something a little cleaner.
I don't want to go through the expense and work of using pavers, was hoping for something I can shovel in about a inch or two thick tamp it down and be all set. I thought I heard on one of those home improvement shows they used something in a walkway that once it was compacted it would be like concrete. But I know you can' believe everything you hear on TV ![]() I was thinking of some sort of crushed granite.... |
#5 |
Learning by Doing
I would do a large heavy gravel. You won't be able to sweep it, but you could use a leaf blower/compressed air. Plus dumping some big gravel will be way easier than trying to build a compacted surface.
If I could only remember to THINK about what I was doing before I did it. |
#6 | |
A Little Of Everything
That's probably about as close to what you're after as you're going to get. |
#7 |
I was looking at the key words "fairly cheep" and "under a porch". To me that means lack of head space to be able to stand up, and dry.
Depending on how much work the poster wants to do, and the type of soils under the porch, several other ideas could be considered. If the soil under the porch is sandy, adding bagged cement powder to the top 2 or 3 inches of soil and mixing will produce a hard surface. If the soil is clay, adding fine bagged lime will produce a hard surface. Both of these will need moisture introduced during the mixing to create the interaction and packing the mixed material is also needed. |
| Display Modes | |
| Water Fall - Black bonding material | cprao | Landscaping & Lawn Care | 3 | 04-23-2011 04:06 PM |
| framing material estimate | maydoug | Building & Construction | 38 | 06-12-2009 02:32 PM |
| Ceiling Ventilation Fan | rjordan392 | HVAC | 1 | 05-20-2009 06:41 PM |
| What roofing material is right for me? | Grumpy | Roofing/Siding | 0 | 07-07-2004 08:41 PM |
