Loctite Instead Of Finish Nails - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 06:11 AM   #1
Rewards Points: 85
Loctite instead of finish nails
I am adding insulation around my windows. When I am ready to put the trim back up do you think there will be a problem using Loctite Molding adhesive instead of finishing nails? The trim is quite old, maybe not as old as the house which is 112 years old.
Thanks,
Matt
mferguson0414 is offline   Reply With Quote
Old 03-05-2012, 06:18 AM   #2
DIY staff
Rewards Points: 7,174
That stuff will hold it--but will be virtually ruined if you ever need to remove it again--
With an antique house removing baseboards and casing is sometimes needed--Why don't you want to nail it?
user1007 (03-06-2012)
Old 03-05-2012, 08:23 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
In my house any nail in the wall can lead to cracked plaster. The vibration goes down the lath and more often than not fractures the nearby plaster.
PoleCat is offline   Reply With Quote
Old 03-05-2012, 09:07 AM   #4
Tom Struble's Avatar
Rewards Points: 2,002
hmm,interesting..
Tom Struble is offline   Reply With Quote
Old 03-05-2012, 09:25 AM   #5
Rewards Points: 3,130
Try predrilling the nail holes.
The Following User Says Thank You to md2lgyk For This Useful Post:
Old 03-05-2012, 10:07 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,194
I have had good luck using RTV (silicone). Not too hard to remove if need be.....only downside....you have to use tape to hold it in place overnight....
Old 03-06-2012, 02:39 PM   #7
Only thing I can think of is that if it doesn't hold right away, may have some movement that you wouldn't risk nailing it.
Also as mentioned will be a pain to remove.
chrisBC is offline   Reply With Quote
Old 03-07-2012, 11:22 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
honestly i dont know how many times ive seen diyer's install trim with only adhesive and no nails.... every time the trim is falling off within a couple years.. you need to use a mechanical fastener to hold the trim on.. over time the paper on the drywall can breakdown do to moisture, or constantly kitting the trim with a vacuum will loosen it.. as the trim loosens the paper on the board comes with it.......
woodworkbykirk is offline   Reply With Quote
Old 03-07-2012, 11:35 PM   #9
Rewards Points: 13,300
Predrill or use a pneumatic nail gun no added damage will be done and it will stay in place.
Just do it right and not the "easy way" or it will just end up be a harder to do do over.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Gymschu (03-08-2012), Minich (03-15-2012)
Old 03-15-2012, 06:22 PM   #10
He's right (joecaption). We have plaster walls as well. The pneumatic gun is so fast, with such slight vibration, I've not had a problem. If you do get some splitting, try a piece of masking take directly over each space you're going to nail.
Minich is offline   Reply With Quote
The Following User Says Thank You to Minich For This Useful Post:
mferguson0414 (03-16-2012)
Old 03-15-2012, 06:22 PM   #11
masking *tape
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Used wrong nails for joist hanger odlaw Remodeling 14 05-28-2011 11:26 AM
nail guns & nails koodawg Tools 4 12-06-2010 11:05 PM
rust stains from finish nails rocketdoctor Building & Construction 1 05-14-2010 04:16 AM
Do I need a Brad or Finish Nailer? atm Carpentry 13 03-10-2010 11:43 PM
