Lock For Metal Casement Window? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-16-2008, 02:58 PM   #1
Post
Lock for metal casement window?
I have a single-pane metal casement window with a "T" crank. The vertical locking mechanism works fine, but only locks the window in a closed position. Is there a supplemental lock I can install that will permit the window to stay open slightly? The metal frame is very narrow (house built in 1954).
I've searched around and not having much luck.
Casey421 is offline   Reply With Quote
Old 09-16-2008, 06:47 PM   #2
Rewards Points: 5,326
Easiest way to limit access would be to just remove the handle. Those old casements didn't move too much without it.
Ron
Tags
casement window , security , window lock , windows
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
Window is 4" narrower than RO, and Drip Cap ? yung-cheng Building & Construction 2 08-07-2008 09:14 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
