'Loading' A Battery Drill - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-23-2012, 04:18 AM   #1
'Loading' a battery drill
Hi all. Newbie here. Starting off with a bit of a 'girlie' question.
I am a bit of a home 'crafter'. Dabble in lots of things.
I love working with wood but I find I have trouble fitting drill bits to the drill tight enough that they don't fall out (and get left in the wood - or worse)
I either have to get hubby to do it if he's home or wait til he gets home from work which is really annoying
Does anyone have any suggestions on how I can hold the barrel thingy (?) more firmly so I can get my drill bits in there more securely and tighter? (And probably keep the OH happy by not breaking his drill bits )
Cheers
Wandererone is offline   Reply With Quote
Old 03-23-2012, 05:20 AM   #2
I told my "girlie" friend to use her adjustable jar opening wrench to loosen or tighten the chuck and it worked for her.
mstew is offline   Reply With Quote
Old 03-23-2012, 05:54 AM   #3
Thanks mstew. Must upload my profile.
For an Aussie girl what exactly is a 'jar opening wrench'?
Old 03-23-2012, 06:11 AM   #4
If you google or seach adjustable jar opener you can find many different types. Just find one either fixed or with a handle and rubber strap that will lock. Here is a pic of one i found real quick. Just use it to grab and tighten or loosen the drill chuck. Also comes in handy with those stubburn pickle jars..lol
Name:  JAR OPENER.jpg
Name:  jar opener 3.jpg
Old 03-23-2012, 07:00 AM   #5
the Musigician
DangerMouse's Avatar
Pliers, vice-grips, or change out the chuck to one with a key.
DM
Old 03-23-2012, 09:19 AM   #6
jschaben
Rewards Points: 502
Cheers
Depending on the drill.. some of the cheaper battery types haven't got a locking (ratcheting) chuck and the bit tends to come loose no matter what you do. My Black and Decker 18V is terrible and the Ryobi I just got rid of was almost as bad. I have Makita's now and they are great, Hitachi and deWalt also have a good chucks. You can tell the difference by when you install the bit, Just twist the chuck a bit by hand and you will hear a faint clicking noise as it locks in position.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 03-23-2012, 09:26 AM   #7
Ravenworks's Avatar
DM
My vote goes for a Jacobs chuck with a key,can be done for under $30 in most cases and be reused on another drill
Ravenworks is offline   Reply With Quote
Old 03-23-2012, 09:43 AM   #8
DIY hobbyist
put in reverse and just grip it.... what brand drill is it ? I can hear mine click as it tightens.
ggold is offline   Reply With Quote
Old 03-23-2012, 11:22 AM   #9
jschaben
Rewards Points: 502
Cheap ones don't, at least my Wally World Black and Decker and Home Depot Ryobi didn't. My DeWalts, Makita's and Hitachi's do. The lady is in Australia so I have no idea what she has available nor what the cost is.
John Schaben
Old 03-23-2012, 04:42 PM   #10
put in reverse and just grip it.....
That, ggold, is my whole problem. I can't grip it tight enough
Old 03-23-2012, 08:05 PM   #11
Ravenworks's Avatar
Is it because the chuck is slippery?
I purposely roughed mine up,and after 3 years of hard use I removed the chuck and roughed up the inside of it because the blades became polished and wouldn't hold a bit tight.
Old 03-24-2012, 12:42 AM   #12
Yes! Ravenworks. That is exactly the problem.
Must be my hands are too soft and smooth Though I don't know why with all the mosaic tiling, painting, gardening etc I've been doing lately.
And its a Hitachi. It's a great drill - just hard for small hands to grip tight.
Maybe I could use a piece of fine sandpaper to hold it? Or one of those non slippy grippy cloths?
That might help a bit.
Old 03-24-2012, 08:25 AM   #13
Ravenworks's Avatar
Try a piece of coarse scotch bright that way if it doesn't work you didn't scuff up your chuck
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 07:00 PM
Cordless Drill Battery Question the1hangingchad Tools 14 08-29-2010 11:57 AM
Need advice on cordless drill brand with a battery life of over 5 years?? stanlam Building & Construction 7 08-09-2010 11:31 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Kawasaki Drill problematic battery? gante Tools 1 03-01-2009 06:57 PM
