Load Bearing Wall Or Not ?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-30-2008, 02:10 AM   #1
load bearing wall or not ??
I want to knock out my kitchen walls to open everything up a bit more. I have the blue print but have no idea how to tell which walls are load bearing and which arnt. can anyone help?
file is too big to upload so please email me if you can help and i can email you the blueprint
thanks in advance
alexkipp327@gmail.com
akipp is offline   Reply With Quote
Old 04-30-2008, 04:11 PM   #2
Custom Cabinet Maker
if the walls are parallel to the joists then they most likely are not bearing.
skymaster is offline   Reply With Quote
Old 04-30-2008, 05:23 PM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 908
If most of the framming on your blueprint is 24" on center and this wall is 16' on center, it could be load bearing.
Sir MixAlot is offline   Reply With Quote
Old 04-30-2008, 05:34 PM   #4
Underground Techie
sevver's Avatar
Does this walls supports go all the way into the basement? The way that I understand things, if a wall on floor 1 is load bearing, then that load has to be transferred to the basement via columns or something.
sevver is offline   Reply With Quote
Old 04-30-2008, 08:11 PM   #5
The joists dont have to be running perpendicular for it to be a load bearing wall. There could easily be a point load from a roof brace or beam in an otherwise non load bearing wall. Even stacked partition walls carry about 6psf of load which should be picked up by a double joist if the lower partition is removed. Hire a local engineer to come out and look at it if your not sure.
ncgrogan is offline   Reply With Quote
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
