Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-11-2008, 12:25 AM   #1
load bearing wall
I have a second floor loft which is 14' 6" ft long that over looks my living room, currently the 14; 6" ft loft is supported at each end with with three 2x6. the only other support for the 14' 6"ft span is a three foot 2x4 wall located 3 feet from one end of the three 2x6 support.
Any advice on what siazr and type of support i will need to use to remove the three ft 2x4 wall and span the entire 14 ft 6 inch loft.
thanks,
markop
markop is offline   Reply With Quote
Old 10-11-2008, 01:01 AM   #2
Moderator
Termite's Avatar
load bearing wall
14'6" isn't an impossible span in most circumstances. At 16" centers, 2x10 joists will span over 15'.
But, in order to say with any certainty, it would be greatly beneficial if you'd post some pictures of the area in question.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
