Liquid Nails For Crown Molding? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-05-2008, 08:21 PM   #1
Question
Liquid nails for crown molding?
Does anyone install crown molding, (or any type of molding), using adhesives, rather than nails? Is this practical/possible. I'd like to avoid all the little finishing nail holes.
Artie2 is offline   Reply With Quote
Old 07-06-2008, 01:35 AM   #2
Registered User
Termite's Avatar
Nope. Crown moulding has to be installed using nails. Not to say it couldn't be done with adhesive, but I think it would be much more trouble than it is worth. There would be a multitude of challenges...
1) The adhesive would be reliant on the paint to bond the crown to the wall. That isn't good enough.
2) Nails will let you draw the crown to the slight variations in the wall. Adhesive won't do that.
3) It would probably look sloppy. The glue might show.
I suppose some trim could be glued if you wanted to. You could probably get away with gluing chair rail or base, but it won't turn out looking like a pro did it.
What's the problem with nail holes? What kind of crown are you using? Nail holes aren't a big problem if you know where to put them and how to fill them depending on the wood and the type of finish.
You should always glue the joints of conventionally installed trim. I always use a biscuit and wood glue on outside corners of crown. I use a biscuit, glue, and a 3 degree back bevel on mitered door and window casing.
Old 07-06-2008, 08:13 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
Possible...but it's going to be messy
You may not have to fill nail holes, but you'll have other issues during install
slickshift is offline   Reply With Quote
Old 07-08-2008, 08:20 AM   #4
Thanks guys. Thats what I like about this forum . . . prevent me from making dumb mistakes.
Old 07-08-2008, 10:38 AM   #5
Another DIY Zombie
Rewards Points: 264
I can not imagine trying to hold an 8' piece of crown (not to mention a 12') in place while the adhesive sets. Nightmare is what I would imagine!
javan is offline   Reply With Quote
Old 07-18-2008, 09:06 PM   #6
Ken at iNeedCrown.com
My Two Cents
I always glue AND nail every single contact surface of my crown moldings. I know it's time consuming, but my crown molding installations have never, ever come apart. They have even gone through a 6.3 earthquake (the Nisqually Quake in Washington, State) and still did not separate. I do like what thekctermite suggested below--using a biscuit on the outside miters--I'll have to try that myself.
Crown Molding Ken is offline   Reply With Quote
Old 07-18-2008, 09:36 PM   #7
747
registered
747's Avatar
Rewards Points: 534
yes when i installed basemolding for my sister in her bathroom i used liquid nails and a few finish nails. Then i caulked above them for a clean look. I just used my finger in a damp washrag ran it over the caulk for a clean fine line look.
747 is offline   Reply With Quote
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 08:11 AM
Getting rid of 'liquid nails' on brick l1r Remodeling 5 04-30-2008 11:57 AM
Removing old Liquid Nails melkisadek Building & Construction 5 01-12-2008 03:21 PM
screw down roof. Can I use Liquid Nails too? aberezin Roofing/Siding 2 11-18-2007 06:45 PM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 11:54 AM
