Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-13-2009, 06:10 PM   #1
Lighting Fixtures in a t0bar ceiling
Hi There,
We have just installed (okay....we had someone come and install) a drop ceiling in our basement but now we do not know how to go about getting the light fixtures down from the studs they are currently attached to. I want to drop them and then add the fixtures but I'm afraid it will be too heavy. Do I have to get pot lights??? Any help would be GREATLY apprectiated!!!!!
DIYMOM&DAD is offline   Reply With Quote
Old 06-14-2009, 08:41 AM   #2
You can get lighting that is made for drop ceilings or you can adapt regular lighting to work in a drop ceiling. What you decide will dictate what you do.
If you drop the lighting into the grid, you will need to add support to the runners to compensate for the added weight.
You can lower a box, to the ceiling plane, but you must support the box as it will carry the weight of the fixture, not the ceiling grid system.
Ron
lighting for low basement ceiling South Portlander Electrical 16 01-28-2012 07:25 AM
HELP! lighting question for vaulted ceiling pauls General Discussion 5 07-03-2010 05:53 PM
ceiling lighting using electrical receptacle with no switch cedar Electrical 8 02-03-2009 07:00 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
