A Light Hearted Thread. - General DIY Discussions - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-07-2012, 01:27 PM   #31
Rewards Points: 2,202
yepps!
(has to be at least 5 characters)
mae-ling is offline   Reply With Quote
Old 10-07-2012, 01:27 PM   #32
Bombastic Idiot
notmrjohn's Avatar
When starting a thread, argue about every piece of advice given. When thread is hi-jacked respond individually to each hi-jacker.
Take part in hi-jackings, the mods are too busy to deal with the victims themselves.
Give erroneous, even potentially dangerous advice. Respond to each objection individually. ( Be judicious, dangerous advice may lead to inability to make any posts at all.)
Do not give detailed instructions, OP will ask for more info. Respond with least info possible, use terms newbies are unfamiliar with, leading to requests for more info, creating self feeding circle.
Put off your own projects to become involved in OP's.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 10-07-2012, 05:39 PM   #33
paper hanger and painter
chrisn's Avatar
Rewards Points: 146
Originally Posted by kwikfishron View Post
You know Chris I spelled it that way just for you and you took the bait.
What would your count be if there were no typos on this site?
One more post for each of us.
10 or 12
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
kwikfishron (10-07-2012)
Old 10-08-2012, 09:26 AM   #34
Bombastic Idiot
notmrjohn's Avatar
Obviate the use of PM's. Ask off topic questions of other posters. For example, chrisn can now ask kwikfishron, "While I have you on the line, can you tell me of any good fishing holes?"
Old 10-09-2012, 06:59 AM   #35
custom user
Rewards Points: 150
I disagree with that.
JasperST is offline   Reply With Quote
Old 10-09-2012, 09:13 AM   #36
Thread killer
Rewards Points: 272
Keep posts short and to the point.
That's right, notmrjohn, no meandering. I usually don't have enough bread crumbs to get home after reading some of yours.
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 10-09-2012, 10:37 AM   #37
Bombastic Idiot
notmrjohn's Avatar
Respond to all arguments; Jasper, no you don't.
Tell other responders that there's a better way than there's; canucker, bread is not up to code here, you are required to tie a string to first word in my posts, follow it back when you reach sig line.
Tell responders their idea is not up to code, even if you do not know the codes where they are, its bound to be not code somewhere.
Old 10-09-2012, 10:45 AM   #38
custom user
Rewards Points: 150
You're just trying to get your post count up!
Old 10-09-2012, 11:04 AM   #39
give information that is not relevant.
Hansel and Gretel were able to follow the bread crumbs to get back.
Old 10-09-2012, 12:45 PM   #40
Bombastic Idiot
notmrjohn's Avatar
jasper, no I'm not.
Old 10-09-2012, 12:50 PM   #41
Bombastic Idiot
notmrjohn's Avatar
mae-ling, no they weren't, birds ate the crumbs, the witch got 'um. The witch's house was not built to code.Ginger bread should never be used for load bearing walls. And she used "No Primer Needed" interior icing on exterior.
Old 10-09-2012, 12:54 PM   #42
Oh yes that is right, birds ate crumbs.
(give wrong answer so get corrected then agree)
Old 10-09-2012, 01:12 PM   #43
Bombastic Idiot
notmrjohn's Avatar
No problem.
(acknowledge agreement with correction of erroneous info)
Old 10-09-2012, 05:07 PM   #44
Rewards Points: 2,238
Let's get back to the subject -
"post count".
Get into your car -
drive along a nice, country road -
count the posts that you see.
Simple!
"RF"
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
gma2rjc (10-09-2012)
Old 10-09-2012, 05:21 PM   #45
Thread killer
Rewards Points: 272
It was code when I started on the post. Can I extend it with string? Don't tell me I can't extend bread crumb trails with string. Licensed posters tell me it's not allowed but won't hurt anything. Never mind, it's my trail and there's no inspectors here, so I'll do what I want. ha!
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Dual-brite motion detector light to operate second light? downunder Electrical 2 09-10-2010 04:48 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 07:57 PM
