Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-19-2009, 03:25 PM   #1
mt232's Avatar
Light fixture same size as electric box
The ceiling light fixture is the same size as the box, leaving no room for error in the sheetrock cut........But, I'm not THAT good. So now I have a little gap (only a fraction of an inch). Any ideas? I have puchase a medallion in the past for a ceiling fan, but they are 10 inches accross and that is way too big for these smaller, fancier lights.
mt232 is offline   Reply With Quote
Old 11-19-2009, 05:15 PM   #2
If the gap is that small, just fill it in with compound. Very odd that a light is that small. The canopy is generally 4+" in diameter.
Ron
Old 11-19-2009, 10:00 PM   #3
nap
You talking to me?
nap's Avatar
got pic's?
Ron's idea is one way I have seen it done. Another is to use wall molding for suspended ceiling used to make a flange but you talk like yours might be round so not real good for that.
Are you sure there was not a flange kit from the manufacturer available.
Like Ron said, I cannot remember any lights that were that close to box size to be much of a problem.
Old 11-20-2009, 04:31 PM   #4
Household Handyman
Ron's suggestion of compound always works, I have used caulk also. It seems to me that our local blue box store has medallions in 6",8",10", and 12" sizes for ceiling fans. I have seen some ceiling fans which have small canopies and as you state, the hole must be cut accurately. One method I saw once, only once mind you, was the home owner took a piece of drywall, cut it about 8" square, put a 45º angle on the sides, put this on the ceiling, then put the fan up. After caulking and painting it didn't look too bad. Each to his own, sometimes. Good Luck, David
More On This Topic
How to Hang a Fan
How to Hang a Fan by eHow.com
Ceiling fans are a way to help cool a room during the summer and circulate warm air during the winter. They're available in many styles and with numerous lighting options to match the decor of any room. There's no need to hire an electrician to hang a... Read More »
Using full sheets of drywall--also called sheetrock--is recommended whenever possible, but designing a project perfectly around the standard size of a sheet of drywall isn't that easy. So measuring when installing drywall and cutting the sheet to your... Read More »
How to Cut Drywall
How to Cut Drywall by Expert Village
Sometimes, you can use a keyhole saw to cut out this. But, I like to use just a regular utility knife. And, you don't have to cut it all the way through. You just scar through the paper and as deep as you can get into the drywall. And, then I usually... Read More »
Hi! My name is Adolph Ramirez from Tampa, Florida. On behalf of Expert Village, this is how to install a ceiling fan. The number one thing to think when you are messing with electricity is safety, safety, safety. You don't want to get electrically... Read More »
Tools For Painting
Tools For Painting by Expert Village
Hello! My name is Grady Johnson and I am a professional painter and today I represent expertvillage.com. Now I am going to talk a little bit about the tools that we need for painting. Now painting tools are pretty universal. You can use them interior... Read More »
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 10:26 PM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 50 09-01-2009 09:20 PM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 09:08 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Replacing Bathroom Light Fixture shapeshifter Electrical 1 02-05-2007 05:33 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
