Light For Closet With No Wiring - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 11:27 AM   #1
Light for Closet with No Wiring
I have a closet with no light wired in it. Is it very expensive to get someone to install one?
Or is it difficult to wire a light myself?
Or is there a good wireless light I can put in there? (like a stick bulb or LED)?
thanks
limitdiy is offline   Reply With Quote
Old 07-06-2011, 12:40 PM   #2
Too Short? Cut it Again!
Hardest part if you are comfortable with basic wiring is getting power to your new location and you will have to run wire for that. If you have open attic access above where you want the light you can pull wire up the wall from an outlet or even across from an existing light fixture if it is wired hot. Adding a wall switch is a bit trickier I guess. If you are adding between the floors pulling the wire will be more challenging but not beyond you if you think it through. Some drywall or plaster work is likely in your future too though.
If you are not sure you are comfortable, or don't want to invest in all you will need one time to pull the wire, have an electrician do it. It should not be a major job.
They do sell all sorts of battery powered "puck" and tube LED lights now that you just switch or tap on and off when you need them. If you watch places like Big Lots they liquidate puck types made by places like Westinghouse and GE, 3-4 per pack for like $10. LEDs get brighter and brighter and with better color rendering indexes all the time. You just attach them with velcro or double face tape.
http://www.google.com/products/catal...ed=0CGUQ8wIwAA
Look in art picture frame catalogs for those that currently have the best color availed. The tube ones are more expensive than the packages of button type I mentioned.
http://www.google.com/products/catal...ed=0CFkQ8wIwAA
The nice thing about LEDs is they don't give off the heat that incandescent or even florescent bulbs do. This is a good thing in a closet.
Old 07-06-2011, 12:51 PM   #3
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
http://www.amazon.com/LED-Output-Spo...xp_grid_pt_2_2
http://www.amazon.com/LED-Wireless-M...e_hi_ai_ps_t_3
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 07-06-2011, 02:33 PM   #4
thank you for the info and the links. After reading what yall wrote, I think I will opt for the led lights. I like sound of the high output led ones. They are more expensive, but i'm guessing you get what you pay for. thanks again.
Old 07-06-2011, 06:14 PM   #5
It doesn't seem like the LED "picture" light gives you an option for the sticky install, only hardware.
beeclay1 is offline   Reply With Quote
Old 07-06-2011, 09:21 PM   #6
jschaben
Rewards Points: 502
thanks
Just another option would be surface mount. This system works pretty well and still looks decent, especially for a closet:
http://www.legrand.us/wiremold/at-ho...l-raceway.aspx
Incidentally, in some places, closet lights had to be flourescent because of heat from incandescents presenting fire hazards. Hence, no bayonet type fixtures.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
Wiring lights with power coming into first light rovers1973 Electrical 2 08-23-2010 07:52 AM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 09:08 AM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 07:25 PM
wiring a new light ugmr10 Electrical 2 12-30-2003 11:59 PM
