Liftmaster Trollley Replacement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-10-2011, 12:07 PM   #1
Liftmaster Trollley replacement
Hi all, I am trying to replace the trolley assembly for my Liftmaster garage door. The metal must have worn out as the motor still operates the chain drive, but the trolley can't engage (so the chain moves but isn't moving the trolley). I'm just curious if anyone has more detailed step by step instructions? The instructions that came with the assembly itself are pretty vague.
Thanks!
welby4404 is offline   Reply With Quote
Old 05-10-2011, 12:12 PM   #2
Household Handyman
Rewards Points: 1,408
Not being there, and not being able to see the trolley itself: I must ask---is the latching mechanism engaged? The system you can pull the cord to release the trolley from the drive mechanism. Just wondering.
Old 05-10-2011, 12:33 PM   #3
Thanks Thurman, the actually trolley itself has sheared the metal off.
Old 05-10-2011, 12:46 PM   #4
Rewards Points: 5,336
You can contact liftmaster for a replacement. If you still have the installation and owner book, it should be in one of those. If not, a simple search on the website with the model number should get it for you. They might even be available from Sears.
I'd research the shearing issue before replacing the trolley. I've never come across that problem in a garage door opener.
Ron.
Old 05-10-2011, 01:03 PM   #5
Rewards Points: 24
I do not have any more details for you, but in general, I would think that the easiest way to do it would be to bring the entire unit down from the ceiling. So, unplug it, disconnect the opener from the door, unbolt the opener from the ceiling and lower it to the floor, remove the pin or bolt holding the track to the door header, and lower that end to the floor. Before going another farther, I would measure exactly where the trolley is on the track, in order to minimize adjustments later. Then I would slacken the belt or chain, get it out of the way, and unbolt the opener from the track. Then, I belive that you will have a stop bolt in the track, which you can remove, after which the trolley should slide off the motor end of the track. Reassembly would simply be the reverse, but before connecting the belt or chain, make sure that the trolley is back to the point where it was when you started. I would be concerned though as to the reason that the trolley failed. It could be something as simple as faulty metal or design, but with the opener removed, check the door; you should be able to raise and lower it with relative ease, and the springs should hold it in the open position. If you determine that the springs are not balanced properly, or if you have any doubts, contact a competant door company in your area. Also check the tracks and rollers, to ensure that it is operating smoothly. Be careful; a garage door is generally the heaviest moving object in a home.
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 05:46 PM
Furnace & Replacement inducer blower louiel HVAC 2 12-28-2010 11:28 PM
Questions about finding replacement blower motor revg HVAC 3 02-14-2010 08:39 PM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 01:48 PM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 04:50 PM
