Lifting Walls - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-30-2012, 09:08 PM   #1
Rewards Points: 2,202
Lifting walls
I have used this type of idea for years. Only thing I add is a 2x4x4' block on the floor behind the upright. Also I use 8' or whatever I need if taller wall. Also use construction adhesive on the scabs/blocks
mae-ling is offline   Reply With Quote
Old 12-31-2012, 12:17 AM   #2
Rewards Points: 956
sorry i dont understand-why would you need to lift up a wall?
federer is offline   Reply With Quote
Old 12-31-2012, 02:53 AM   #3
Everywhere I have worked we build them flat on the ground, sheet them then raise them. In reno work when doing additions we will even put house-wrap on and premark the top plates for rafters before we stand them.
Old 12-31-2012, 07:04 AM   #4
DIY staff
Rewards Points: 7,174
Those look real handy---I've used steel wall jacks on some projects, but I never owned them--
I like your jacks---self sticking----very handy---
Old 12-31-2012, 08:01 AM   #5
Rewards Points: 3,130
Now that's handy! Wish I'd seen it a couple of years ago when I was building my house.
Old 12-31-2012, 11:28 AM   #6
Using 2 of these about 1/4 way in on each end 2 of us lifted a 38' long 2x6 sheethed and house-wraped wall.
2 people lift up one notch on one jack, then 2 of us go to the other one and lift up one notch on the other jack. Reposition your hands and lift to the next notch, back and forth you go.
As a safety stop we nail a 4' (approx) 2x6 about every 8-12' on the rim joist so it is sticking up about 12".
Old 12-31-2012, 11:40 AM   #7
DIY staff
That little prop would have save me a lot of trouble on several jobs---
Old 01-02-2013, 01:11 AM   #8
Rewards Points: 956
ohh gotcha. you mean for construction.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
How bad are unencapsulated knee walls? deerhunter Building & Construction 0 11-02-2010 10:41 PM
