Lift Master 1/3 Hp Garage Door Opener - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 04:27 PM   #1
Question
Lift master 1/3 hp garage door opener
Garage door does not stay shut pops back up unless remote button is pushed a second time. I have tried to adjust force up/ down with no results. There is no obstacle in laser eye. Any ideas of what else I can try ?
Kbrodsky is offline   Reply With Quote
Old 05-02-2010, 05:15 PM   #2
Rewards Points: 1,016
Lazer eye bumped out of alignment with one another - or dirty?
Old 05-02-2010, 05:19 PM   #3
Can you tell me the best way to re align eyes?
Old 05-02-2010, 09:30 PM   #4
firehawkmph's Avatar
Rewards Points: 1,922
Kbrod,
It sounds like your down travel is letting the door travel too far. When it hits the floor, the motor is still pushing the door down and thinks it is hitting something and reverses itself. Try backing off the down travel adjustment a quarter of a turn at a time.
Also check your down force adjustment. It may be set too light. Try turning it up about a 1/16 of a turn at a time. When you change this setting, you need to check to see if the door still reverses itself when it does actually strike an object. I usually try to stop the door when it is about elbow height by grabbing the bottom. If the down force it set properly, it should reverse itself. If you can't stop it with one hand, it is set too tight.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 05-03-2010, 06:46 PM   #5
Question
Thanks for the reply. I adjusted the travel & up and down force, cleaned and aligned eyes. Still having the problem of the door going back up. Any thoughts?
Old 05-04-2010, 08:38 PM   #6
Kb,
Try this link to liftmasters site for your 1/3 hp opener. Go to page 23 and read the couple of sections on adjustments.
http://www.liftmaster.com/pdfdocs/114A3077.pdf
Go through there procedures and check your setting one more time. Is your opener making a clicking noise when the door reverses and/or the led lights on the electric eyes flashing? The eyes normally are lit solid. When something breaks the beam, they flash. If there is a problem in the opener itself, they may flash a trouble code. If your door is reversing and the leds on the eyes aren't flashing, it sounds like you need more down force or your down travel limit is still letting the door travel too far. Did you unhook the opener from the door and operate the door manually to see if there are any spots where it binds or doesn't travel smoothly?
Mike Hawkins
Old 05-04-2010, 09:14 PM   #7
Question
Thanks Mike, I let you know how it goes. I noticed both eyed have a solid green light. I'm pretty sure one should be amber. Is that correct?
Old 05-04-2010, 09:24 PM   #8
Kb,
I just had to go out and look at mine. One is green, one amber. Depends on how old your opener is though. Mine is less than a year. Some of the older models used green eyes on both. I wouldn't worry about the color so much, as long as they are lit solid, they should be seeing each other.
Mike Hawkins
Old 05-05-2010, 02:42 PM   #9
Got it, Thanks Mike was actually the up travel adjustment
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Convert garage door to high lift door? 65cobra Building & Construction 5 06-23-2009 08:38 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Turning a garage into Master Suite kettles1998 Building & Construction 4 08-28-2008 08:31 PM
