LifeBreath Motor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-18-2009, 09:34 PM   #1
LifeBreath motor
I have a LifeBreath 200MAX, an air processing and removal system for the home, and I believe the motor is shot. The unit is original with the house which was built 12 years ago. Anyone familiar with this system and if so, is it possible to replace the motor? Hope this was descriptive enough, if not I can provide more details.
Thanx in advance!
TaskMaster is offline   Reply With Quote
Old 06-18-2009, 10:16 PM   #2
Rewards Points: 5,336
Did you contact the manufacturer?
Ron
Old 06-20-2009, 12:27 PM   #3
Ron,
Seems like the obvious thing to do....no actually. I located the company online, they are out of Canada and they do list a number. I thought about it but before I did I wanted to check here. I am a pretty handy DIY'er and my experiences contacting businesses that deal in these products is that they will do anything to get more money out of you without assisting by phone or email. They want to sell a new one or send a tech out at ALOT per hour. The new unit sells for $1200. Thanks
Old 06-20-2009, 01:58 PM   #4
Another option would be remove the motor and bring it in for either repair or to tell you it's shot. Unless this is a special motor, a repair facility should be able to troubleshoot it for you.
Ron
Old 06-20-2009, 03:58 PM   #5
If you post a schematic we can step you through troubleshooting this thing.
Old 06-21-2009, 07:43 AM   #6
TM, google info lists this as a 5 speed motor, so not off the shelf type at your local ace hardware. Either way it carries a 5 year warranty and should be replaceable if you are careful.
Do as mentioned post some info here or go one line for the trouble shooting manual. If it comes down to replace or rebuild there will be specs on the motor housing and supplier info.
Highly unlikely this motor is only used by Lifebreath, much more likely it was supplied by a US company, like GE or Emerson or someone big in HVAC supply.
Chemist1961 is offline   Reply With Quote
Old 06-24-2009, 05:45 AM   #7
Why don't you contact a technician who can deal with your motor problem? I guess http://ductworks.net can help you out with your problem, as they have over 50,000 HVAC parts available to us including furnaces, AC, heat pumps, custom ductworks, insulated fiber ductwork and replacement parts for most model types.
tombaker is offline   Reply With Quote
Old 06-24-2009, 04:23 PM   #8
I heard the company had been indicted for fraud and prostitution. Have they made bail already?
Ron
Oiling Trane XB1000 AC Fan Motor Build HVAC 5 06-19-2009 04:05 PM
dayton fan motor Turk Electrical 1 02-27-2009 05:38 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 05:13 PM
Air Compressor Motor Hums, Trips Breaker pointertopica HVAC 10 12-02-2008 10:20 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 06:30 PM
