Life Span Of Masonry Diamond Segmented Blade - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-18-2010, 03:42 PM   #1
Rewards Points: 562
life span of masonry diamond segmented blade
never used one before now. Cut a half dozen sidewalk edges to match depth. It is a 4.5"segmented diamond blade in an Dewalt angle grinder.
Pulled it out yesterday and cut two small sections and the blade has no grit left. It was right after I smoothed 2 quarter size rocks in the aggregate. Did the rocks ruin the blade or are they short life in nature???
ANY tips to longer life of blades appreciated
4just1don is offline   Reply With Quote
Old 06-18-2010, 04:37 PM   #2
DIY staff
Rewards Points: 7,174
You might try a 7 1/4 inch blade for your Skill saw--I was using it with a dribble of water--Got over 70 feet of cut ,at full depth--the blade still has a lot of life.(not sure about the saw though)
If you try this make sure that you are plugged into a gcfi--and your saw and cords are grounded.
There are dry cutting blades in that size if dust is not a concern.
Heat is the enemy of diamond blades--life is much shorter when cutting dry.
---Mike---
Old 06-18-2010, 10:04 PM   #3
Rewards Points: 562
thanks
thanks for replying. What I am doing is grinding top of sidewalk slabs even. The sidewalk police were at work again and doesnt allow a 1/4" difference from one square to another. Tree roots and settling changes some slightly. If you 'drag' your toe from one to another it cant catch or jump.
There was NO directions with the wheel when bought. Its an Omega brand from Mennards,,,if that makes a difference.
So SHOULD one use small amounts of water to keep diamond blade cooler??and this would extend expected life?? Does that throw alot of goop?
can diamond blades cut/grind large quarter size rocks,,,or they too hard???
Old 06-18-2010, 10:57 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That isn't a job for a low cost Chinese diamond blade to begin with. A diamond cup maybe!
Go buy a stone grinding cup for that grinder and do it that way. Menard's won't have one, try a real live construction supply company or go to a Ready-Mix company.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
oh'mike (06-19-2010)
Old 06-19-2010, 06:37 PM   #5
DIY staff
Sorry ,I misunderstood the use.
Like Bud suggested--a grinding cup is used for smoothing.----However,before attempting the final trim-
I would take that cutting blade and saw a series of shallow cuts (like you do when notching a 2x4)
An then knock off the slits with a hammer---That will get the bulk of the waste out of there fast--
Then use the cup to make the rough out look presentable.
----Mike----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
47_47 (06-21-2010), jomama45 (06-20-2010)
Old 06-22-2010, 02:37 PM   #6
As was stated, water on a dry cut diamond blade will surely extend the life but there are also several variables: The quality of the diamond blade is obviously a concern. $16.00 Home Center blades vs a high diamond concentration on a blade that comes from a construction supply house $30-$50 dollars should be night and day differance. One of the biggest killers of a diamond blade is "elbow grease." In other words, using your strength to push the blade through the product instead of taking it slow and letting the diamond break down properly through the cut. Good way to warp a blade real quick. Variable speeds on slow starting out with diamond tooling will let you know how fast you can eventually go.
Last edited by Gary in WA; 03-16-2011 at 07:33 PM. Reason: removed ad link in post body
FEDSAWDAVE is offline   Reply With Quote
Whats the life span of a cricket?? 4just1don Pest Control 4 10-22-2014 02:03 AM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Air duck life span / Air flow ACE II HVAC 3 04-20-2010 08:05 AM
What is the average life span of a sump pump? Fred311 Plumbing 8 01-27-2010 09:41 PM
