Leveling Perimeter Ceiling L-channel: - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-22-2014, 04:20 PM   #1
Rewards Points: 67
Leveling perimeter ceiling L-channel:
I'm installing a Ceiling Link drop ceiling in a small basement family room (11' x 20').
The first step is to attach the L-channel around the perimeter. I've got everything worked out except establishing a continuous level line around all four walls.
I'm working with a very limited budget, and I don't have a laser level or 6 foot carpenter's level (I do have a decent 2' level.)
I'd appreciate any good DIY tips on how to pencil in a continuous level line around the room. TIA.
oldberkeley is offline   Reply With Quote
Old 03-22-2014, 04:35 PM   #2
Rewards Points: 2,096
Google has all kinds of ideas on how to make a water hose level. Just don't ruin a bucket by drilling a hole near the bottom like one ignorant did when siphoning over the top works just as well.
http://www.finehomebuilding.com/how-...ter-level.aspx
Old 03-22-2014, 06:21 PM   #3
Rewards Points: 144
Measure up from the floor on two corners and run a string like between these two points.Use your two foot level to check the string and adjust to level.Not the best but zero cost.
mako1 is offline   Reply With Quote
Old 03-22-2014, 09:48 PM   #4
Rewards Points: 1,014
Water level
http://www.wikihow.com/Use-a-Water-Level
Anti-wingnut is offline   Reply With Quote
Old 03-25-2014, 08:06 PM   #5
Rewards Points: 284
Just measure down from the floor joists. Snap a line or use a couple marks and a straight edge(straight 2x4, 1x?). The ceiling link system attaches directly to floor joists so that is what you need to be level with. If the wall is parallel to floor joist lay a 2x4 perpendicular to floor joists and touching wall then mark the wall. Being perfectly level is not required but you do want straight lines meaning no sags or humps.
JustinK is offline   Reply With Quote
Old 03-25-2014, 08:31 PM   #6
Civil Engineer
Rewards Points: 4,956
Rent a laser level, $25 for the day or so. Best $25 you will ever spend.
Daniel Holzman is online now   Reply With Quote
Old 03-26-2014, 07:06 AM   #7
Rewards Points: 1,300
How about a string level and a chalk line. Pretty low cost.
danpik is offline   Reply With Quote
Old 03-26-2014, 08:24 AM   #8
firehawkmph's Avatar
Rewards Points: 1,922
+1
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-26-2014, 09:22 AM   #9
landfillwizard's Avatar
Rewards Points: 516
Home Depot has many laser levels that work well for leveling ceilings. Most are less than renting a laser level. I have used one many times have been happy with the results.
landfillwizard is offline   Reply With Quote
What to do with this old ceiling? mudworm Building & Construction 4 07-17-2011 04:54 PM
Resilient Channel For Basement Ceiling Stingray Remodeling 7 02-07-2010 12:14 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Leveling an old ceiling jduhoski40 Building & Construction 4 01-24-2007 11:54 AM
